Sol from the 15th of September 2020.
eroel
Been thanked: 724 times
Post by eroel » Wed Sep 16, 2020 3:24 pm
Hi:
Another bad weather day, just had a gap for taking a set of "surface" and other of the prominences so to make one FD and its versions.
Thanks for looking and have a nice day you all.
Sol del 15 de septiembre del 2020-Solarmax 90-DS-BF30-1pos-Spline2.jpg (2.76 MiB) Viewed 150 times
Sol del 15 de septiembre del 2020-Solarmax 90-DS-BF30-1pos-neg-Spline2.jpg (2.51 MiB) Viewed 150 times
Sol del 15 de septiembre del 2020-Solarmax 90-DS-BF30-1neg-pos-Spline2.jpg (3.04 MiB) Viewed 150 times
solarnoob
Oh, I get it now!
Oh, I get it now!
Has thanked: 15 times
Been thanked: 32 times
Re: Sol from the 15th of September 2020.
Post by solarnoob » Wed Sep 16, 2020 3:30 pm
Great looking pictures Eric.
Frank
Lunt LS50Ha, LS100Ha
ZWO ASI174
Sky-watcher Solarquest mount
dhkaiser
Has thanked: 575 times
Been thanked: 533 times
Post by dhkaiser » Wed Sep 16, 2020 3:34 pm
Super images with the poor viewing conditions. Are your input levels low on the SSM?
Dan
Lunt LS60THa, Lunt LS60FHa DS
Lunt 102mm ED, Herschel Wedge
Celestron C6 SCT
Ioptron AZ Pro mount, CG-4 mount
ASI 178 mono
South central Indiana
USA
eroel
Post by eroel » Wed Sep 16, 2020 3:54 pm
Frank and Dan, thank you.
Dan, I calibrated the input of the SSM and set it permanetly to 0.8 input for a clean nice day, so you can imagine how the day looked when it just shows 0.4 and lower as shown in the graph with a lot of shortcuts.
I don not know if it is O.K. to set it as I do, or you have to reset it each time you use it. ¿do you know?
Has thanked: 564 times
Been thanked: 312 times
Post by ffellah » Wed Sep 16, 2020 3:56 pm
Very nice captures Eric.
dhkaiser
Post by dhkaiser » Wed Sep 16, 2020 7:23 pm
Just received my SSM this last week. The newer model self calibrates the input so I can't give advice on which is right. Just noticed the graph.
Dan
Celestron C6 SCT
ASI 178 mono
USA
eroel
Post by eroel » Wed Sep 16, 2020 8:50 pm
Dan:
Lets find out how to do it, so to have a standard to compare graphs.
Thank you.
Has thanked: 1024 times
Been thanked: 1162 times
Post by DeepSolar64 » Wed Sep 16, 2020 11:06 pm
You did really well for such a short session.
Has thanked: 2079 times
Been thanked: 719 times
Post by Montana » Thu Sep 17, 2020 1:31 pm
Well done Eric, these are super pictures despite the conditions :bow :hamster:
I do the same as you Eric, I keep the SSM set at 0.8 for clear skies. When clouds pass over the input naturally lowers as there is no Sun. It would be a bit of fiddle to keep a pin in the hole to maintain 0.8. If there is no sun the input will be low and the seeing terrible, but I guess you can work that out with your eyeballs :)
eroel
Post by eroel » Thu Sep 17, 2020 1:46 pm
Alexandra and James, thanks for the feedback.
BTW Alexandra, nice to know that you do the same with the SSM, so thanks for your comment.
Have a nice day, here it is clouded and raining.
