Seattle Sun- Smoke filtered sunlight
Has thanked: 811 times
Been thanked: 710 times
Post by Carbon60 » Thu Sep 17, 2020 9:21 pm
A good friend of mine living in Seattle sent me this image of the Sun taken on an i-phone using only natural sunlight filtered through smokey skies from the unprecedented West Coast wild fires.
Seattle Sun.jpeg (477.64 KiB) Viewed 176 times
rsfoto
Has thanked: 1292 times
Been thanked: 919 times
Re: Seattle Sun- Smoke filtered sunlight
Post by rsfoto » Thu Sep 17, 2020 10:53 pm
Hi Stu,
That is incredible how far the smoke has already travelled.
:shock: :shock: :shock: :shock:
Has thanked: 1024 times
Been thanked: 1162 times
Post by DeepSolar64 » Fri Sep 18, 2020 4:37 am
I remember seeing the sun like this when we had a forest fire within 4 miles of my home two summers ago.
Has thanked: 2079 times
Been thanked: 719 times
Post by Montana » Fri Sep 18, 2020 7:06 am
It is very sad to see this Stu but makes a super picture ;) It seems from Spaceweather today that the smoke is getting very high into the atmosphere and can now be seen in Europe :(
EGRAY_OBSERVATORY
Been thanked: 590 times
Post by EGRAY_OBSERVATORY » Fri Sep 18, 2020 10:24 am
As Alexandra says, even in the Netherlands the effects of the smoke seems to have travelled.
Apparently Mount Wilson Observatory was at risk from the fires themselves...
Spaceweather.com says;- "The Bobcat Fire, which erupted on Sept. 6th in the Angeles National Forest, is out of control and threatening the historic observatory. On Tuesday afternoon, the blaze was within 500 feet of the facility. Firefighters saved it using a variety of tactics, including carving out lines by hand and with bulldozers, setting strategic backfires (indeed, the photo above might be a backfire), and dropping water from airplanes. After two harrowing nights of firefighting, the observatory still stands. unquote...
Bob Yoesle
Been thanked: 27 times
Post by Bob Yoesle » Sat Sep 19, 2020 12:39 am
Smoke filtering.jpg (67.86 KiB) Viewed 128 times
About seven days ago in eastern Washington State. Visibility about 800 meters. Then it got worse, for a few days visibility less than 400 meters, and no sun at all. We've had to wear an N95 mask for the smoke for the limited times we went outside (let alone Covid 19 exposure prevention when grocery shopping in town). With everything else going on, it truly felt apocalyptic.
Today there is some relief with improved visibility and rain in the forecast...
At the same time, it's been very dark at night. Two days after the picture above (Sept 13) a friend got the darkest reading ever on his dark sky meter, with zenith sky brightness below 23 m/arcsec^2:
Mckeag SQM Mosier OR.jpg (123.77 KiB) Viewed 128 times
"Our clear, moonless night sky ZSB is nominally about 21.7. Last night we reached that value soon after the start of astronomical dusk. ZSB continued to decrease until moonrise at 01:45, reaching darkest measurements of 23.02 mpsas. Following moonrise ZSB increased steadily, reaching 21.4 10 minutes after start of astronomical dawn."
Note the AQI inset in the graphic above - the Air Quality Index - was in the "hazardous" 400-500 range and above:
Has thanked: 1953 times
Been thanked: 760 times
Post by marktownley » Sat Sep 19, 2020 9:05 am
Cool pic! Reminds me when the storm in october? a couple of 3 years ago brought up Saharan dust to the UK and had a similar effect on the sun.
