The Sun - 20th September 2020
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Still windy today but not quite so bad as yesterday so I took the Evostar out for a look visually to start off. Picked up an ES 4.7mm 82 degree eyepiece this week primarily for use on Mars, thought I would unleash it on the Sun Didn't expect much at 212x but actually in moments of good seeing (and it wasn't bad at all today) it was brilliant. Some of the best views of granulation I've had visually I think. For imaging I switched to the Bresser again as the gusty breeze would have made life difficult with the bigger scope.
Some nice development in the prom in Ca-k from yesterday
David
- Has thanked: 20950 times
- Been thanked: 10588 times
Re: The Sun - 20th September 2020
Impressive disks Dave!
Thanks Mark. The disk ended up a little darker today as I tried to bring out the prom more.
David
Waiting David to see what you image over the next few days - with a possible/probable new AR about to arrive.
The Cak prom has come out very well.
Can i suggest David, that a little sharpening of your Cak image will show more definition of the surface detail. (I've used PaintShopPro to show your image as sharpened and now attached).
Thanks
Thanks
- 20200920_Ca-K_FD_AR102xs_16_sharper3.5x.jpg (1.34 MiB) Viewed 523 times
- Has thanked: 17960 times
- Been thanked: 17106 times
Very nice images David and Terry I do think the Sharpening does indeed show the surface detail better.
- Has thanked: 18105 times
- Been thanked: 8941 times
These are fabulous David! it sounds like you had one of those beautiful solar moments when viewing the granulation
I love the CaK prom
I love the CaK prom
- JochenM
- Been thanked: 1619 times
Looking good, David. Nice to see the faint CaK prom sticking its proverbial head out.
Thanks all for the kind comments.
Thanks Terry, sadly I will be at work all week so next imaging opportunity will be on the weekend. With this one you are right I probably could have pushed the sharpening a bit more. I'm always conscious of over-cooking it but in this case it probably needed a touch more.EGRAY_OBSERVATORY wrote: ↑Sun Sep 20, 2020 11:23 pm Waiting David to see what you image over the next few days - with a possible/probable new AR about to arrive.
Thanks
David
- Has thanked: 8588 times
- Been thanked: 8324 times
Nice FD images, David.
- Has thanked: 9823 times
- Been thanked: 5826 times
Very well done. I like your 3D disc and the yellow colouring of the Sun is very well balanced and at least for my eyes very pleasant.
Also the colouring of your CaK image is very good.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Fine discs, David.
AR102S is a quite short refractor but the Cak image is good, have you stopped the aperture ?
Raf
Thanks, yes I stop it down to 50mm to get a sharp image. It's horrible @ full aperturekrakatoa1883 wrote: ↑Thu Sep 24, 2020 4:47 pm Fine discs, David.
David
