New AR today
RodAstro
Has thanked: 154 times
Been thanked: 171 times
New AR today
Post by RodAstro » Mon Sep 21, 2020 8:27 pm
This is the best I could get as the seeing was boiling and a very hazy sky, can't half tell the planes are back now it's getting cooler.
There was lots of movement in the prom changing every minute and very bright features.
Nice big loop as well.
Looks like it is going to get interesting for a while so the clouds and rain are rolling in here in the UK.
Rod
New AR 5-15pm.jpg (184.14 KiB) Viewed 307 times
Has thanked: 1717 times
Been thanked: 1719 times
Re: New AR today
Post by DeepSolar64 » Mon Sep 21, 2020 9:47 pm
Your photo agrees very well with recent SDO images.
Starry Jack
Has thanked: 98 times
Been thanked: 149 times
Re: New AR today
Post by Starry Jack » Mon Sep 21, 2020 10:43 pm
I love the compare between the two! Fascinating
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
EGRAY_OBSERVATORY
Been thanked: 1120 times
Re: New AR today
Post by EGRAY_OBSERVATORY » Tue Sep 22, 2020 12:20 am
Hi Rod,
Considering your weather, that's a very good image of the prom and thanks for sharing
Has thanked: 33 times
Been thanked: 113 times
Re: New AR today
Post by Valery » Tue Sep 22, 2020 2:46 am
Thanks, Rod. Very nice observing report despite a bad seeing.
The only question remains - what is the equipment used.
Has thanked: 2899 times
Been thanked: 1171 times
Re: New AR today
Post by marktownley » Tue Sep 22, 2020 5:33 am
Good shot Rod! Nice surge.
Has thanked: 1207 times
Been thanked: 1025 times
Re: New AR today
Post by Carbon60 » Tue Sep 22, 2020 6:05 am
Nice capture, Rod.
Has thanked: 2895 times
Been thanked: 1099 times
Re: New AR today
Post by Montana » Tue Sep 22, 2020 7:04 am
Beautiful!! that hot spot was tiny and yet you caught such detail :hamster: :bow
RodAstro
Re: New AR today
Post by RodAstro » Tue Sep 22, 2020 10:56 am
Thanks all
Looking at GONG this morning the activity seems to have moved slightly so we maybe in for a decent bit of activity as at the moment the area of activity is quite large, I hope so.
I used my 6" Zeiss f15 with a Quark unit off a daystar ds60 with a UV/IR filter. I have to use a reducer before the Quark telecentric to get the FL down, for this I use a four element air spaced Pixco one for a camera, this unit keeps the focal plane in the same place, otherwise the quark would be up inside the tube with any other reducer. I also use a barlow just before the camera as the quark etalon is a bit zonal but the centre is quite good. For a wider field I leave the barlow out and use flats in Fire Capture, this does a reasonable job but still not perfect so more work processing.
I am using a ZWO asi174MM.
I have tried two other Quarks, combo and telecentric and moved the the telecentric and combo fronts between then all, not a lot of difference, what you gain with one you lose something else so will stick with this one until it packs up.
It all sounds a little complicated but this is to do with the Zeiss coude system, even if I wanted to I can't cut the tube down, this way it works very well visually and quite well photographically.
Cheers Rod
Has thanked: 889 times
Been thanked: 476 times
Re: New AR today
Post by ffellah » Tue Sep 22, 2020 11:32 am
Nice catch, Rod
