Mostly Ha Series on Oct 14th
- Been thanked: 4427 times
Good day everyone...
I was able to take advantage of the clear skies over lunch on Wednesday and was quite happy to see a new AR and many proms to image. Seeing was better than average which allowed more higher resolution images to be taken.
The first image is a composite of separate disk and limb images taken through the LS80T/LS75FHa/B1800Ha solar scope and and ASI174MM camera: There we several targets for the modded CR-150/DSII/B1800Ha scope, using a 2.7x Telecentric ahead of the 174MM camera: The relatively stable seeing allowed the images of the proms to turn out as well: Before closing up the observatory I grabbed a full disk CaK image through the Stellarvue 110mm, f7 scope using the Lunt CaK Wedge/B1800CaK module and the ASI1600MM camera: I was glad to get a chance to view and image since this is the most activity on the sun in some time
As always, questions and comments are welcome.
Re: Mostly Ha Series on Oct 14th
Thank you Brian - with so many cracking a fabulous images showing everything available to be seen.
Beautiful colouring and presentation too...
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Been thanked: 4980 times
Brian:
Beautiful session, all images are super.
- Has thanked: 17849 times
- Been thanked: 16992 times
All your images are super, Brian but I love the second one. The colored one. It looks so naturally luminous!!
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Nice imaging Brian, you really nailed the emerging AR.
Martin
Martin
- Has thanked: 2464 times
- Been thanked: 4880 times
My thanks to everyone for the comments and feedback on the session...always appreciated
- Has thanked: 9319 times
- Been thanked: 6156 times
These are really really good, Brian ! The proms are super... glad you had a good session, it is a lot of fun.
- Been thanked: 6691 times
Franco and Pedro...
Always appreciate your comments guys...thanks very much
- Has thanked: 20813 times
- Been thanked: 10484 times
Great shots Brian! Try running that 110f7 at 60 or 70mm for the CaK FD, you're going to get a much better sampling rate with the camera without losing resolution on what you've got on the image above (f7 with that camera is really undersampling so you're not getting 110mm of resolution). You'll find stopping down will help with the seeing, will give a higher f-ratio at the filter and so higher contrast and you will get a considerably sharper image as SA will be considerably reduced. Win win all round...
Hi Mark...
Thanks for your comments on the images and the suggestion to make the 110 down for CaK.
I have been thinking of doing this, but not had time to make up the aperture mask. The other scopes I used for this had a 2 part dew cap with a smaller central opening but not this one. I think I can put something together easily...just need to do it
