I'm learning how to use my newly acquired Lunt CaK module (straight-through, B600). So far tried with my 90/660 mm Celestron achromat and with the GSO RC8 (with Aries ERF). Unfortunately there was literally nothing on the Sun at the time of capture, but the image quality seems promising (all from the 90 mm achro, PGR Chameleon 3 mono/ICX445, AviStack 2, ImPPG):
SW Barlow 2x:
PowerMate 2.5x:
(Seeing wasn't good enough for any useful results from the RC8.)
The good news is that in my case the PM 2.5x does not give any reflections like the ones described here. There were some problems, though; in some configurations I was getting a distorted, "streaky" image:
Strangely enough, this was improved by just rotating the CaK module by 90 degrees (with camera, Barlow and telescope unchanged). I don't remember exactly, I might have also been moving the module up and down the drawtube (and compensating by moving the camera relative to the PowerMate). Perhaps differential heating (and distortion) of the module's front mini-ERF by a too-small input light cone? Definitely something to experiment with further.
First CaK results
- GreatAttractor
- Has thanked: 749 times
- Been thanked: 757 times
- Has thanked: 65 times
- Been thanked: 4459 times
Re: First CaK results
Good initial trials with your CaK module...as you gain experience and more activity to fine tune the process you'll be getting great images for sure!!!
- Has thanked: 18105 times
- Been thanked: 8941 times
Great to see these Filip CaK is a tricky to get sorted at first, I'm still working on the C11 but the TEC140 seems to be good now
Nice to see the 1st light/CaK images Filipp. Cak is my favourite and I know you will achieve some fav results...
- Been thanked: 5016 times
