Todays discs November 10, 2020,
Yes there are two new perturbations visible in the Sourheastern quadrant at about -13 and -32° latitude.
Here the 120 minutes timelapse of AR 12871 https://rainerehlert.com/00_SCHForum/11 ... SR_USM.mp4
In White LIght there are 4 pores visible in the lower perturbation area. In the upper nothing is visible yet.
Full disk 10-11-2020
- Has thanked: 9412 times
- Been thanked: 5574 times
Re: Full disk 10-11-2020
Excellent images as usual and the animation show that AR2781 is quieting-down somewhat, but I bet when it leaves the SW edge - it may well go with a bang, as others have done in the past.
Thanks Rainer
Regards
Thanks Rainer
Regards
- Been thanked: 16694 times
Rainer,
You captured the area around AR12781 very well. It's not as overexposed and the disturbances in the spicule field radiating outwards from the AR is beautiful. I bet it would look awesome colorized.
The animation is very nice too. Do I see a couple of mini-flares going on?
- Has thanked: 20438 times
- Been thanked: 10245 times
Great disks and movie Rainer, I was expecting to see the palm tree creep in at the end
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Nice Imaging Rainer, thanks for sharing.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Good job as usual Rainer. Hope the new area is an active one.
Dan
South central Indiana
USA
USA
- Been thanked: 8791 times
Superb images Rainer and a very interesting animation, there is a flash to the upper right which doesn't seem to be associated with the spot groups. All you need now is an X-class flare
Hi Mark,marktownley wrote: ↑Wed Nov 11, 2020 6:45 am Great disks and movie Rainer, I was expecting to see the palm tree creep in at the end
No, in this case the Palm Tree creep is history as I am pointing to the West and the Palm Tree is in this case in the East and so the creep would be at the beginning of the video bue then comes my Observatory wall
- Been thanked: 4904 times
- Been thanked: 4340 times
Superb full disk images Rainer
