Intermittent clouds and bad seeing today. So animation and white light not possible. Even H-alpha is not as usual ... You can see it on the upper right piece of image.
AR 2781 is gone and AR 2872 is not a big show. Above AR 2782 is a disturbance with cycle 25 polarity. Perhaps it develops ?
Full disk 15-11-2020
- rsfoto
- Has thanked: 9417 times
- Been thanked: 5582 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Full disk 15-11-2020
Thanks for sharing, at least you managed to get something. I've not had any luck since the 6th November because of the bad weather here.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17581 times
- Been thanked: 16696 times
I had clouds today. The sun peeked out right at Sunset and I tried to get the Orion70 out on it for WL but no success. Too low in the trees. You saved my butt today Rainer. Nice view!
- Has thanked: 17672 times
- Been thanked: 8792 times
Superb images Rainer you say 2782 is not a big show, but it looks big and beautiful to me
- Been thanked: 4900 times
