November 17 2020 Observations
- Has thanked: 17840 times
- Been thanked: 16976 times
Session time is 11:00am to 11:58am EST local time ( US ). Skies are clear with windy conditions. Seeing well below average. Temp is 52F.
Coronado SolarMax II 60 DS. 16x and 21.5x ( Ha )
Today poor seeing caused me to really have to work at it to see details. Everything was really soft. The only two things I could see fairly easily on the disc is the plage to AR12782 now entering the SW quadrant and a broken open-looped filament in the NE. Closer and more deliberant observations revealed more details. A new disturbance in the SE and two filaments SE of AR12782. I was also able with difficulty to pick up a filament NW of the new disturbance. Also another NW of AR12782 associated with a weak disturbance located there. I could not see the disturbance today. I can also see a small filament in the NW.
Surprisingly the prominences are not that hard to see, even in doublestack. Three decent ones in the NE with the northernmost one near the half-broken open loop filament. I can actually see two tiny proms above it! The fourth is a hedgerow below the emerging disturbance. GONG Cerro Tololo shows a couple of other small fainter ones elsewhere around the disc but I cannot see them.
The mottles are really soft today but visible covering the solar disc.
Orion 70mm Solar Telescope. 27.5x and 41.5x ( WL )
I can see a single spot and the faculae which corresponds to the disturbance seen in the SE in Ha. I can only barely see the dark spot in the middle that marks the umbra. SDO shows a light-bridged umbra. Seeing will not permit higher magnifications which would show it. I see no other details on the white-light disc. The granulation is rendered invisible by the seeing.
Carpe Diem!
Carpe Diem!
- rsfoto
- Has thanked: 9710 times
- Been thanked: 5769 times
Re: November 17 2020 Observations
Hi James,
Very good. I am clouded out ince yesterday and for the region quite cold.
- Been thanked: 4900 times
Thanks James for the latest.
Awaiting a clear-spell here for some R2 imagery.
Terry. You just need some D2 to go with it. Then you would have an R2D2 system!
- Has thanked: 20779 times
- Been thanked: 10462 times
Thanks James, just cloud and drizzle here today, one of my colleagues described it as 'fieldwork weather'.
I hope I get some clear skies over the weekend.
What kind of “ fieldwork “?marktownley wrote: ↑Tue Nov 17, 2020 10:39 pm Thanks James, just cloud and drizzle here today, one of my colleagues described it as 'fieldwork weather'.
- Been thanked: 4422 times
Good to see your review James!
Overcast with cold north wind and snow here...maybe clear tomorrow though.
Good luck on clear skies. In your climate an observatory is a BIG plus!
The sort of weather on a geological field trip in the UK - wet, rainy, damp, windy. Basically weather only the determined go out in
- Has thanked: 17970 times
- Been thanked: 8904 times
Sounds a bit of a struggle today James but at least you got out observing I'm glad you are feeling better now though, sorry to hear you were sick
- Been thanked: 4971 times
James:
Thanks, at my place it was clouded the 17th and today too.
Greetings,
Greetings,
Thank you Alexandra. I am just now really getting over it. I am glad it wasn't COVID-19!
