Sunday Sun 22nd November 2020 - AR2783 & FD
- Has thanked: 8418 times
- Been thanked: 8162 times
I had about 30 minutes of Sun this morning, so I used the limited time available to capture a Ha full disk and, with good seeing this morning, a close view of AR2783. My FDs are usually imaged with a Basler acA1920-155um, which work best as multi-pane mosaics to match the image scale with my Lunt 60 fitted with a 2.5x PowerMate. Recent single pane images using a 1.5x barlow have been under sampled. This morning I wanted to trial my Basler acA2440-75um with smaller pixels as an alternative. Usually this suffers from NRs like crazy, although today I managed to reduce these to almost nothing using a homemade tilted nosepiece. Unfortunately the FD doesn't quite fit onto the sensor by a whisker, so two panes were required (I'm sure I can address this with suitable spacing).
The close views were captured on my 150mm/Lunt 35 mod. The wider view is a mosaic of six images.
First up, Ha FDs on the Lunt. Tuning could have been tighter.
20201122_Ha_FD_Mono by Stuart Green, on Flickr
20201122_Ha_FD_Colour by Stuart Green, on Flickr
And the closer views with the 150mm mod.
Mosaic...
20201122_Ha_AR2783 by Stuart Green, on Flickr
20201122_Ha_AR2783_Crop by Stuart Green, on Flickr
Thanks for looking.
Mosaic...
Thanks for looking.
- Has thanked: 896 times
- Been thanked: 314 times
Re: Sunday Sun 22nd November 2020 - AR2783 & FD
You did good. Love the heart-shaped spot....
Call me Geoff.
I do what I do because I want to, and because I can....
Doesn't mean I know what I'm doing, though!
- Has thanked: 214 times
- Been thanked: 146 times
Gorgeous details Stuart!
Fabio
Fabio
Flickr album https://www.flickr.com/photos/190949744@N08/
- Has thanked: 9412 times
- Been thanked: 5573 times
Hi Stu,
Great images and looks like the Sun is awakening ...
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Has thanked: 20437 times
- Been thanked: 10245 times
Nice shots Stu, i'm just processing some from today too.
- Has thanked: 9145 times
- Been thanked: 6025 times
A beautiful set, Stu, showing great detail of the AR.
- Has thanked: 17572 times
- Been thanked: 16694 times
It's amazing what you imagers can do in such a short time. I bought a ZWO camera but haven't had a chance to play with it at all. Between work, wife, babysitting kids, helping stepdaughter move and visiting Sarah, my daughter I have had little time. Solar observing, sleep and prayer being my only refuge. I'll get there in time. I am gonna start out imaging white light. I feel it would be easier.
Sounds like a good idea James, as starting at WL should be easy enough to get the feel of the camera and whatever computer is used.
Best Wishes
Best Wishes
- Has thanked: 3292 times
- Been thanked: 1887 times
Nice images as usual.
I had a few sights of the big prom whilst having a play with my kit.
At one point it looked like it was made out of lace.
Later it looked like a cock hen standing on the left looking over a hen looking left.
Cheers. Andrew.
Cheers. Andrew.
White light also seems easier with my DSLR and iPhone too. And visually it is easier too!EGRAY_OBSERVATORY wrote: ↑Sun Nov 22, 2020 8:22 pm Sounds like a good idea James, as starting at WL should be easy enough to get the feel of the camera and whatever computer is used.
Best Wishes
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
- krakatoa1883
- Has thanked: 153 times
Great images, Stu, excellent work.
- Been thanked: 4340 times
Nice set of images Stu...well done
- Has thanked: 1171 times
- Been thanked: 1360 times
