Sunday Sunshine 22nd November
Has thanked: 20757 times
Been thanked: 10442 times
Hi All,
Apologies if i'm not as busy on here of late, work is just sapping all my time, meaning while I can find the time for a quick scan of posts I don't have the opportunity to respond to all. So, if I haven't responded to your post don't take offence, i'm just struggling to fit everything in the day!
Sunday however offered clear skies, and with the 7 foot winter pier installed and peeping over the 6 foot high neighbours fence, I have a sunny window all year round from midday till just before sunset - woohoo! I was excited to get the scopes out, and looking through the double stacked 50mm Ha setup visually for a while I have to say I think is the busiest i've seen the sun since Easter 2019. It was very relaxing and calming to be able to take the time to look properly through the eyepiece with the hustle and bustle of life surrounding the rest of the week. Even Mrs T enjoyed a look through the scope in between her doing the garden.
I was keen to dust off the cobwebs and grab some images though, and started off with the Ha full disk - 50mm Lunt etalon double stacked with a Quark. Seeing was never going to be great, and some bits of the image are softer than others, but hey ho - better than clouds!
ImageHa-FD-DS-bw by Mark Townley, on Flickr
Spoilt for things to look at - visually the prom in the northern hemisphere looked great!
Imageprom-ha-bw by Mark Townley, on Flickr
Forgot to sort the tilter out and a bit of banding as a result, need to add that job to the list!
Imageactive-regions-Ha-bw by Mark Townley, on Flickr
My favourites were in CaK though, and raising the gamma in ImPPG meant the spicule ring and proms came out quite nicely I thought (for CaK) while still retaining some disk contrast. Be sure to double click the disk for the full size view in Flickr to see the limb, particularly around where the new activity is emerging. I like the surge jet!
ImageCaK-FD-bw by Mark Townley, on Flickr
These were shot at 60mm f16 for the disk, and 60mm f28 for the closeup. Very borderline results for the seeing, but pleased they came out.
Imagear-cak-bw by Mark Townley, on Flickr
All in all a nice way to spend a sunday!
Hope you like,
Alto
Has thanked: 962 times
Been thanked: 335 times
Re: Sunday Sunshine 22nd November
Post by Alto »
Great shots Mark.
Call me Geoff.
Thanks Geoff!
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Beautiful, detailed images, Mark
Franco :bow
Fabio_Imm
Has thanked: 214 times
Been thanked: 146 times
Post by Fabio_Imm »
Well done Mark!
Really fine looking discs :bow
Fabio
Thanks Franco and Fabio, here's a shot of the active region and the departing limb.
Imageactive-regions-other-side-ha-bw by Mark Townley, on Flickr
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Fine images Mark and the "Tree" prom is so fine and sharp.
Thanks for finding the time to show us these.
Has thanked: 8523 times
Been thanked: 8259 times
Post by Carbon60 »
An excellent session, Mark. Very nice,crisp, images. As you say, lots going on, for a change.
Thanks Terry, thanks Stu.
Lowjiber
Has thanked: 238 times
Been thanked: 109 times
Post by Lowjiber »
Excellent work, Mark! I spent ten minutes just going thru all the shots and learning. Thanks for the shares.
Clear Skies
John
Lunt 60 PT B/1200, Quark-Chromosphere, and ZWO ASI120MM & ASI174MM Cams.
Has thanked: 17925 times
Been thanked: 8894 times
Wow!! so much detail in the images compared to my 40mm :bow :bow :bow
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Excellent session, Mark!
Wish you more of warm sunny days.
Thanks everyone!
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
This is an excellent series of images images Mark :bow
Nice to see you could take advantage of the day!
