Saturday 5th December 2020
Has thanked: 3259 times
Been thanked: 1242 times
Post by Montana » Sat Dec 05, 2020 6:31 pm
Some sunshine!!!! well bits of it anyway. I had a small blue patch and managed to catch the CaK through the PST with the Chameleon and then an hour later manged the DS Halpha PST.
ImageSun_115338_05_12_2020 by Alexandra Hart, on Flickr
ImageSun_115338_05_12_2020_ f colour by Alexandra Hart, on Flickr
Image20-12-05 13-22-50 by Alexandra Hart, on Flickr
Image2020-12-05 Chameleon 1-6x by Alexandra Hart, on Flickr
Image2020-12-05 Chameleon 1-6x f colour by Alexandra Hart, on Flickr
One question (and you know I won't act on it) but my CaK PST is getting very dark now. Originally back in 2009 I could image with a 2x Barlow in winter. Now I can barely get 1/19 second at prime focus. Which bit has likely gone wrong? I need to slowly digest and mull over the problem.
dhkaiser
Has thanked: 770 times
Been thanked: 701 times
Re: Saturday 5th December 2020
Post by dhkaiser » Sat Dec 05, 2020 6:49 pm
Can't help with the CaK, plenty of detail in the Ha. Newton rings?
Dan
Lunt LS60THa, Lunt LS60FHa DS
Lunt 102mm ED, William Optics ZS73, Herschel Wedge
Celestron C6 SCT
Ioptron AZ Pro mount, CG-4 mount
ASI 178 mono
South central Indiana
USA
solardave
Has thanked: 10 times
Been thanked: 75 times
Post by solardave » Sat Dec 05, 2020 6:56 pm
nice images Alexandra good job
tak 102fs solarmax40 ds es ed80 cornado 90mm filter bf10 bf 30 skynyx 2-2 mono camera lunt 2inch wl wedge lunt b1800 cak mod
JochenM
Has thanked: 367 times
Been thanked: 702 times
Post by JochenM » Sat Dec 05, 2020 7:39 pm
Nice set of images, Alexandra.
I'm not sure how a CaK PST is constructed exactly; but maybe some muck buildup on the lens inside the filter unit? Had something similar happen with my Lunt CaK module last year. Opened it up, quick clean and problem solved.
Stardust5858
Has thanked: 187 times
Been thanked: 208 times
Post by Stardust5858 » Sat Dec 05, 2020 8:04 pm
Lovely captures. Thanks for sharing my birthday sun. It's cloudy here.
Lunt 60mm Double Stack.
80ed +Baader K-Line.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
12inch OO Newtonian.
Nec6 Eq Mount.
mattwastell
Has thanked: 2 times
Been thanked: 36 times
Post by mattwastell » Sat Dec 05, 2020 8:04 pm
Hi Alexandra - glad you found some blue sky.
The prom disc looks great - a few ghostly proms.
I have a similar finding with my LS60 - I have had one blue filter replaced due to it 'fogging' up. In my last sessions I noticed that the camera needed a much higher exposure (the filter is fine) but during the course of the session it changed significantly & I had to wind the exposure down - atmospheric?
Matt Wastell
Look up, look good!
http://www.pbase.com/mattwastell
Has thanked: 1018 times
Been thanked: 542 times
Post by ffellah » Sat Dec 05, 2020 9:44 pm
Fabulous pics Alexandra !
JohnW
Been thanked: 93 times
Post by JohnW » Sat Dec 05, 2020 9:57 pm
Nice set of pics Alexandra - glad to see you got some viewing in while the AR's are still there. Cheers, John W.
Has thanked: 2095 times
Been thanked: 1950 times
Post by DeepSolar64 » Sun Dec 06, 2020 2:36 am
Why bless your little hart! You have gotten some sunshine! Nice images. I especially loved the colored CaK images and the limb prominence one.
Has thanked: 3477 times
Been thanked: 1440 times
Post by marktownley » Sun Dec 06, 2020 8:51 am
Hi Alexandra.
You caught both wavelengths well, it's nice to get some sunshine.
If your CaK exposures are so low it's because the filters have rusted. There are 2 sets of filters that rust in a CaK PST; one is in the eyepiece holder - see if it unscrews. The other is where the blue band meets the base of the gold tube - see if it unscrews. The good news is that the rusted filters can simply be replaced by a Baader K line, and the other bit of good news is that the all important CaK filter does not fail or degrade - it is a different type of filter than the ones that fail. The rust is just the same issue that happens with Ha blocking filters. The likely bad news will be access to the filters, and the tube / ep holder not being able to unscrew because of loctite in the threads. The ep holder you should do with a boa.
Have a go and see if it unscrews.
yltansg
Has thanked: 866 times
Been thanked: 477 times
Post by yltansg » Sun Dec 06, 2020 1:06 pm
Dear Alexandra,
Nice images from both PSTs. Your Chameleon is doing very well. Hope you resolve the CAK PST issue.
Alfred
Been thanked: 671 times
Post by MapleRidge » Sun Dec 06, 2020 1:13 pm
Great disks Alexandra :bow
I am always impresses with your perseverance to image the low sun through the bedroom window ;)
Hope that you can clean up the CaK base don Marks suggestions!
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
Post by Montana » Sun Dec 06, 2020 4:39 pm
Thanks everyone :)
Problem one, the Newton's Rings with the Chameleon. With the very kind help from Brian Ritchie (Smerral) he pointed me to this plugin for Photoshop
http://ft.rognemedia.no/
Video tutorial https://www.youtube.com/watch?v=FDM4lEw ... e=youtu.be
and Wow!! the NRs be gone. It takes a little playing around to understand and experiment with what it is doing but I think this looks better
Image2020-12-05 Chameleon 1-6x PS a by Alexandra Hart, on Flickr
The second problem, the CaK PST
Thanks Mark, I knew you were going to say I needed to dismantle it. Apollo also agrees that the filters are rusting. I need to be brave one day and take it apart, I really didn't like the Halpha PST dismantling but at least I know now that the hairdryer works and is more gentle with the boa ;)
I am currently suffering grief because it is like both you and Apollo have told me that my faithful friend has a terminal illness :(
Post by marktownley » Sun Dec 06, 2020 4:47 pm
That pattern suppressor looks interesting - will have to explore...
Has thanked: 1377 times
Been thanked: 1207 times
Post by Carbon60 » Sun Dec 06, 2020 5:20 pm
Wow, that Plugin looks amazing. Nice job. Beautiful images, Alexandra.
I can’t speak about the CaK PST, but I dismantled my Lunt modules and cleaned off some sort of cloudy grime from all of the surfaces a few months ago. I haven’t checked to see if anything has reappeared, but your post has prompted me to take another look.
Post by DeepSolar64 » Sun Dec 06, 2020 6:22 pm
I am a bit worried about my Coronado BF15s rusting. So far so good.
rsfoto
Has thanked: 2156 times
Been thanked: 1574 times
Post by rsfoto » Sun Dec 06, 2020 10:11 pm
Hi Alexandra,
Excellent results.
eroel
Been thanked: 1143 times
Post by eroel » Sun Dec 06, 2020 11:54 pm
Alexandra:
A nice session anyway, you got the Sun.
As for your question, I did change one rusted filter from my CaK PST (the one near the eyepiece of the PST). First I used a Baader K line filter, but now I use the Baader Venus filter and it is much brighter. This is the one I have in my CaK mod.+Best regards,
yltansg
Post by yltansg » Mon Dec 07, 2020 10:05 am
Thanks Alexandra.
Downloaded the pattern suppressor and will explore later.
Alfred
Post by Montana » Tue Dec 08, 2020 4:02 pm
Eric, is that the 1.25" filter?
Post by marktownley » Tue Dec 08, 2020 4:23 pm
https://www.365astronomy.com/Baader-U-F ... ished.html
I think I would avoid any purchases until you have a route forward - if you are not able to dissect the PST another approach is needed...
