Post
by DeepSolar64 » Fri Dec 25, 2020 2:38 am
I missed out today Rainer. Clouds and heavy rain. The temperature has dropped 20 degrees in just the last couple of hours. It's snowing now and the porch out back is white. 28F outside. We are on the back side of the weather system and it won't last long. Tomorrow's high is only forecast to be 27F. It won't even reach freezing! Still, if the sun is out I will be on it.
Thanks for the views. Those spots in AR12795 are coming along nicely and look at that radial pattern around that big spot of AR12794!
Merry Christmas Rainer. Go cut you a palm Christmas Tree!!
DeepSolar64 on Fri Dec 25, 2020 5:15 pm, edited 1 time in total.
