PowerMate or Barlow for H-Alpha Video
- Has thanked: 98 times
- Been thanked: 149 times
I want higher mag for my DSO, Lunar and H-Alpha work (and whitelight too).
I have:
- 80mm Orion ED f7.5
- 152mm acrho Explore Scientific f6.5
- Quark
- ASI 174mm for Solar and Lunar
- Mallincam DSC10c for DSO
I RARELY do visual anymore. So...
-Should I consider PowerMate or Barlow
-If PowerMate, is there a less expensive alternative?
-2" or 1.25"?
-Paracor
Many thanks,
Jack
I have:
- Quark
-2" or 1.25"?
-Paracor
Many thanks,
Jack
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- Has thanked: 1915 times
- Been thanked: 1404 times
Re: PowerMate or Barlow for H-Alpha Video
Hi Jack,
Reading your message I asked myself " What is the difference between a Powermate and a Barlow ? " and I found this explanation.
https://www.televue.com/engine/TV3b_pag ... &Tab=_back
So from what I understood, the difference is only for visual and depending of the focal length of the eyepiece.
BTW I have never used a Barlow or Powermate in my life as I use my Canon Telephoto extenders 1.4X or 2.0X, because most of my light cameras are connected to my telescopes via a Canon bayonet.
- Has thanked: 2882 times
- Been thanked: 1162 times
Unless your seeing is ASTRONOMICALLY good, I wouldn't even waste time (and money) with a Quark/174 trying to up the amplification factor up even more. You're just oversampling. You might as well just increase the image size 2x in post processing because you're not going to actually increase resolution...
You can't bend physics!
Mark and Rainier,
It's the physics and the math which confuses me so I get lost in marketing hype.
I appreciate the insight. If the primary difference is for visual then I can consider I rarely am visual.
If my camera limits me then that's another issue.
I neli3ve it was you , Mark, who turned me on to adding a Barlow to the nose of the Quark to straighten the light path then a focal Reducer on the camera and I did see a boost in contrast so I was wondering if I'm improving DSO viewing if I could also optimize H alpha.
Best,
Jack
Best,
Jack
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
- Has thanked: 1701 times
- Been thanked: 1708 times
I use a barlow for visual but since you don’t do visual much anymore it’s a moot point.
- Oh, I get it now!
- Has thanked: 15 times
- Been thanked: 13 times
I start with the wrong equipment to add a Quark for imaging, but it "is what it is"...
You have an 80mm f/7.5 scope and a Quark, so you already have about an f/31 "solution" which is recommended. A "slower" scope (focal ratio) will give only a dimmer image and a "faster" scope would not be ideal for the Quark because it is preferable to receive a parallel beam (or whatever the correct terminology is) - already achieved.
With good seeing conditions, you may see one or two arc seconds of seeing. With the 174, 4.2x included Barlow and the scope you are "pushing things" a bit to resolve 0.7 arc seconds when 1 - 2 arc seconds is suggested for excellent seeing conditions if you try to add in a Barlow to the mix. You would become oversampled e.g. more bits of data than pieces of content (info).
So for both issues, you are already about "optimal" and so there is nothing to be gained from adding a Barlow when imaging. Moving to a situation that is oversampled would simply mean more (unnecessary) storage, slower transfer rates, lower fps, longer processing times, more noise (lower Signal-to-noise ratio - SNR) and absolutely nothing to be gained.
For my own setup with a 178, I should probably think about binning the data 2x2 to compensate for the tiny pixels (178 has almost half the size of the 174 pixels). Ideally, I would also stop my scope down to 80mm from 100mm to get a reasonable focal ratio, but since the focal ratio "thing" for Quarks is just a guide (not an absolute cut-off), I'm told that it should be OK ASIS and trying both options (like binning and not binning, stopping down (vs needing a UV/IR filter that I just stomped up for vs just a piece of cardboard on the front objective) is the way to go.
Simon
Simon
Great and interesting explanation Simon.
I never considered binning the sun since I equate binning with decreasing exposure on do objects.
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
- Has thanked: 12 times
- Been thanked: 16 times
For the Quark, its 4.2x already magnifies. But you also mention DSO, lunar, and white light, and there presumably a magnifier might help, no?
I assume a simple Barlow would be fine. The Powermate most is useful if either an eyepiece follows (visual) or if a narrowband filter follows.
George
George
