January 7th - A day of Filaments
Has thanked: 10 times
Been thanked: 518 times
Post by MapleRidge » Sat Jan 09, 2021 5:59 am
Good day everyone...
It was a clear, cool day here on Thursday (around -7C while at the scope) and I had an hour to do some imaging before noon hour. The seeing was not very good, but the images came out better than I expected.
The first image is a full disk composite using separate disk and limb images, with the limb inverted. Thsi was imaged through the LS80T/LS75FHa/B1800Ha double stacked solar scope with an ASI174MM camera:
The image below is a triple stack using the DSII module as the third etalon:
There was little disk activity but numerous filaments were visible as well as a few small proms. The images below were imaged through the modded iStar 150mm OTA/DSII double stack/B1800Ha, with a 3x focal extender and the ASI174MM. This is a multi frame mosaic of the SW quadrant of the disk with several filaments and some limited activity. The mosaic is uneven due to the seeing...I tried to clean it up as best I could ;) :
The SE limb had several filaments as well:
The final images are of the proms:
That's it from Thursday...working on Fridays images now :lol:
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, OAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
Has thanked: 1196 times
Been thanked: 1012 times
Re: January 7th - A day of Filaments
Post by Carbon60 » Sat Jan 09, 2021 6:34 am
A mere -7 deg C, Brian..... :lol: We complain when it's -1.
Anyhow, despite the seeing conditions these are great images. Nicely done.
Has thanked: 2882 times
Been thanked: 1162 times
Post by marktownley » Sat Jan 09, 2021 8:41 am
Nice images Brian! Glad you got some sun, that's what i'm hoping for this weekend too.
I'm curious if there's a reason you use the 174 camera for the full disks with the double stack? The 1600 smaller pixels offer much better sampling and would give better resolution.
EGRAY_OBSERVATORY
Been thanked: 1111 times
Post by EGRAY_OBSERVATORY » Sat Jan 09, 2021 11:54 am
Well-captured Brian of the proms and surface detail.
Thanks vm
Post by MapleRidge » Sat Jan 09, 2021 3:16 pm
Stuart, Mark, and Terry...
Thanks for your comments and feedback on the images...always appreciated :bow
Stuart...our winter has been pretty benign so far, with no major blizzards or super cold days/nights (so far :lol:). We have had snow cover since Christmas day which is nice. El Nino winters tend to have a smaller range on extremes with more frequent warm spells. Late January through the end of February is typically the coldest period, before the longer days and more intense sun start to warm us up again. We haven't had the 'Polar Vortex' yet either, so the -35C nights may not materialize...but, I'm not holding my breath. Travel to a southern climate this winter is not going to happen, so the milder it is the happier Sandy will be ;)
Mark, the ASI1600 is in the works to be tried for full disk solar after I finish rationalizing the solar scopes. For me, the full disks are meant as a reference as to where features are and then image in higher resolution where there are features. The ASI290 would do a nice job but need to mosaic the full disk...seeing isn't my friend most days and I'd sooner have an even lower resolution image than a blotchy higher resolution shot. Just my perspective on it.
8' Diameter Dome
rsfoto
Has thanked: 1915 times
Been thanked: 1404 times
Post by rsfoto » Sat Jan 09, 2021 3:58 pm
Hi Brian,
Excellent images
Highbury Mark
Has thanked: 56 times
Been thanked: 78 times
Post by Highbury Mark » Sat Jan 09, 2021 4:08 pm
Super images Brian. Such a sweet set up to double stack the LS80 with the LS75Fha.
dhkaiser
Has thanked: 713 times
Been thanked: 663 times
Post by dhkaiser » Sat Jan 09, 2021 4:47 pm
Nice set Brian. -7 C is cold!
Dan
Lunt LS60THa, Lunt LS60FHa DS
Lunt 102mm ED, William Optics ZS73, Herschel Wedge
Celestron C6 SCT
Ioptron AZ Pro mount, CG-4 mount
ASI 178 mono
South central Indiana
USA
Post by MapleRidge » Sat Jan 09, 2021 11:36 pm
Rainer, Mark, and Dan...
Always appreciate the feedback...thanks guys :bow
Dan, temps are all relative to what you typically experience. I'd say -7F is cold :lol:
8' Diameter Dome
eroel
Been thanked: 1125 times
Post by eroel » Sun Jan 10, 2021 12:45 am
Brian:
Beautiful images on a very cold session.
Best wishes and keep safe.
Post by marktownley » Sun Jan 10, 2021 7:58 am
Definitely worth trying. The 75/80 double stack and a 2x barlow when seeing allows would give a nice field of view and near perfect sampling. The fov being the white box.
astronomy_tools_fov (6).png (109.45 KiB) Viewed 85 times
Has thanked: 2885 times
Been thanked: 1094 times
Post by Montana » Sun Jan 10, 2021 12:09 pm
Excellent set Brian, I really enjoyed all the close ups of filaments :bow :hamster:
We too have had snow on the ground since the 27th Dec, most unusual but I think we are going to have some warmer temperatures this week which will shift it. You need to keep Sandy happy though, maybe you could decorate the house with palm trees (I am sure Rainer could donate), drink cocktails and pretend to go to the Caribbean for a week :)
Has thanked: 883 times
Been thanked: 474 times
Post by ffellah » Sun Jan 10, 2021 12:12 pm
A truly beautiful set, Brian, in spite of the seeeing
Franco :band
Post by MapleRidge » Sun Jan 10, 2021 1:11 pm
Thank you Alexandra and Franco...always appreciate your comments :bow
Mark, I ran some images with the 1600 on Saturday morning. Sill processing but will post later once I get them finished.
8' Diameter Dome
MAURITS
Has thanked: 19 times
Been thanked: 80 times
Post by MAURITS » Sun Jan 10, 2021 3:13 pm
Very nice images Brian
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
