Sol from the 9th of January 2021.
- Been thanked: 1125 times
Hi:
Today started nice it was clear and sunny, but the neighbor tree was on the way, so had to wait and when the Sun was high enough to clear the tree, then clouds came with as lot of wind, so had to keep waiting for small gaps to take some shots.
Here is the result and thanks for looking.
Have a nice Sunday.
Have a nice Sunday.
- Has thanked: 2883 times
- Been thanked: 1162 times
Re: Sol from the 9th of January 2021.
Mighty fine shots Eric, especially given those tempestuous clouds.
- Has thanked: 1196 times
- Been thanked: 1012 times
Great images, Eric. Fantastic proms.
- Has thanked: 2885 times
- Been thanked: 1094 times
Excellent! what is interesting is that the prominence seems to be much more prominent in CaK than H-alpha, that is quite unusual, obviously quite energic
- Has thanked: 10 times
- Been thanked: 518 times
Excellent image Eric...well done!!!
You CaK setup really performs on the proms...I can only get them on occasion with my Lunt filter.
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, OAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
8' Diameter Dome
- Been thanked: 1111 times
Fab prom images Eric.
Watch for the S.E.Limb where a spot may be emerging...
- Has thanked: 19 times
- Been thanked: 80 times
Alexandra, Mark, Stu, Brian and Terry, thanks for the feedback.
Alexandra and Brian, concerning the CaK shots, well what I do is to overexpose the prominence recording using a low Gamma, then after aligning and stacking 25% to 30% of the best recordings from a 600 frame video, I use the Lazzo tool to separate the protuberances so to get the background black, then with the lazzo tool I use levels over each protuberance so to get the backgound leveled, finally I make a composite with the surface image and keep processing to get the final image.
You can see the settings I use from the 2 photos taken of the recordings using Lucam-Recorder, hope it helps.
Best regards to all and let keep us safe.
