Page 1 of 1
Sol from the 9th of January 2021.
Posted: Sun Jan 10, 2021 1:06 am
by eroel
Re: Sol from the 9th of January 2021.
Posted: Sun Jan 10, 2021 8:04 am
by marktownley
Mighty fine shots Eric, especially given those tempestuous clouds.
Posted: Sun Jan 10, 2021 11:33 am
by Carbon60
Great images, Eric. Fantastic proms.
Posted: Sun Jan 10, 2021 12:14 pm
by Montana
Excellent! what is interesting is that the prominence seems to be much more prominent in CaK than H-alpha, that is quite unusual, obviously quite energic
Posted: Sun Jan 10, 2021 1:08 pm
by MapleRidge
Excellent image Eric...well done!!!
You CaK setup really performs on the proms...I can only get them on occasion with my Lunt filter.
Posted: Sun Jan 10, 2021 1:30 pm
by EGRAY_OBSERVATORY
Fab prom images Eric.
Watch for the S.E.Limb where a spot may be emerging...
Cheers
Posted: Sun Jan 10, 2021 3:10 pm
by MAURITS
Super Eric.
Posted: Sun Jan 10, 2021 3:14 pm
by eroel
Alexandra, Mark, Stu, Brian and Terry, thanks for the feedback.
Alexandra and Brian, concerning the CaK shots, well what I do is to overexpose the prominence recording using a low Gamma, then after aligning and stacking 25% to 30% of the best recordings from a 600 frame video, I use the Lazzo tool to separate the protuberances so to get the background black, then with the lazzo tool I use levels over each protuberance so to get the backgound leveled, finally I make a composite with the surface image and keep processing to get the final image.
You can see the settings I use from the 2 photos taken of the recordings using Lucam-Recorder, hope it helps.
Best regards to all and let keep us safe.
- CaK-protuberance.jpg (327.92 KiB) Viewed 247 times
- Cak-surface.jpg (405.21 KiB) Viewed 247 times
