January 12 2021 Observations. Calm Sun.
Has thanked: 1701 times
Been thanked: 1708 times
Post by DeepSolar64 » Tue Jan 12, 2021 5:35 pm
Session time is 11:41am until 12:13pm EST local time ( US ). Partly cloudy skies with poor seeing. Temperature is 43F.
Coronado SolarMax II 60 DS. 16x and 21.5x ( Ha )
I can see an arc filament on the south-central disc that is broken up into seven smaller pieces mirroring what GONG CT shows. The 16x eyepiece ( Coronado 25mm ) reveals only 4 but the additional power of the Lunt 19mm eyepiece ( 21.5x ) is able to resolve the filament(s) better giving me a count of seven individuals. This was indeed a challenge. It almost certainly would have been easier with the SMII90. I also got a filament in the SE just inward of a prominence but I lack the resolution to tell whether it joins it as a filaprom. I also see a small difficult filament in the NNW.
I see three prominences. One on the SE, a fairly bright one in the NW and a faint one in the SW. None show a lot of detail appearing as fuzzies on the limb.
I see two plages without difficulty. One in the SE and another in the upper SW quadrant.
The mottles are of low contrast today but still visible across the disc.
Orion 70mm Solar Telescope. 27.5x ( WL )
The sun is absolutely featureless today. No spots or pores. No faculae, not even granulation. The limb shimmers in waves in the poor seeing.
All while listening to Beethoven's Seventh Symphony.
Carpe Lumen!
Has thanked: 2882 times
Been thanked: 1162 times
Re: January 12 2021 Observations. Calm Sun.
Post by marktownley » Tue Jan 12, 2021 7:44 pm
Good report James, thank you! the sun has quietened off quite a bit, it'll pick up soon though i'm sure. Keep the reports coming and sunny skies!
Post by DeepSolar64 » Wed Jan 13, 2021 5:49 am
Thank you Mr. Townley. May sunny skies find you. I am curious what scope Mrs. T got you.
Post by marktownley » Wed Jan 13, 2021 6:53 am
Hi James.
She got me a 127mm fraunhofer refractor... https://www.firstlightoptics.com/bresse ... r-ota.html
I already have something similar, a Meade AR5, but while it is good at Ha wavelengths there is a lot of spherical aberration at CaK. The Bresser is the same rebranded OTA as the Explore Scientific version, both being a 20 year (?) newer version of the Meade. This newer optics are much better in CaK wavelengths. I've already stripped the finder off the new Bresser and replaced the focuser with the Moonlite I had on the Meade.
I have a few uses for it, at full aperture it will make a great Ha scope when seeing doesn't allow the HaT. For Calcium I can stop it down to 120mm to give me f10 which will mate nicely with my IMX174 camera, telecentric and filter assembly when seeing is good. I am also in the process of making some aperture stops one of which will be 80mm, giving me f15, which is pretty much spot on perfect sampling at these wavelengths for a ZWO290MM camera - this will use no barlows etc and so light levels will be kept up and aberrations down.
There's no point me even trying it on the sun until a couple of months time when the sun is higher and my seeing is better, something to look forward to in spring.
Has thanked: 1195 times
Been thanked: 1012 times
Post by Carbon60 » Wed Jan 13, 2021 6:59 am
Thanks for your report, James. Very quiet indeed.
Post by DeepSolar64 » Wed Jan 13, 2021 7:05 am
Very nice Mark! It's an inch more aperture than the 102mm Celestron I use for white light. I too plan to upgrade to a larger refractor in the future by going to an Astro-Tech AT130EDT triplet apo. It's significantly more expensive than your Bresser but much cheaper than a comparable Takahashi. I do have an Astro-Tech AT72EDII apo doublet and it performs wonderfully with little to no color.
I look forward to your posts with this new refractor.
EGRAY_OBSERVATORY
Been thanked: 1111 times
Post by EGRAY_OBSERVATORY » Wed Jan 13, 2021 12:20 pm
Thanks James for your report.
Marks' newbie scope looks interesting and eventually to see some results should be even more interesting...
I have the Meade 127mm APO-Triplet, but is so long and very heavy, that not suitable within the observatory for Solar use, but my Meade ETX-125mm
Maksutov-Cassegrain Scope - is to be trialled in WL for use in my anticipated new mini-observatory (elsewhere in my garden for low-down Sun/winter-use), if a suitable camera will be able to fit between the scope's rear-end and its' fork-mount base or will be satisfactory-imaging through its' flip-mirror system. I do believe that I already do have enough available cameras and FR's for close-up's of Sun-spot activity for even all year round use...
A warmer weather project in the offing...
Post by marktownley » Wed Jan 13, 2021 8:25 pm
You use your scopes for night time too James?
Post by marktownley » Wed Jan 13, 2021 8:27 pm
That 125 might be a bit big for winter use Terry, (just my experience!) - you might find you get better results with something considerably smaller. Of course you may be gifted with magical seeing where you are in winter, but knowing the conditions in Blighty I would be surprised.
Post by DeepSolar64 » Thu Jan 14, 2021 5:52 am
I do use both the Celestron 102 and the Astro-Tech AT72EDII for nighttime use though more so in the warmer weather months. I bought the AT72EDII mainly for a grab and go scope for nighttime use. I am well equipped for visual nighttime observing with a splendid old Criterion 6" F8 newtonian as well as an old Coulter 10.1" Dobsonian and a newer Sky-Watcher 12" Dobsonian.
The little Orion 70 is a dedicated white light solar telescope. It has a fixed in place glass filter over the objective.
I record my nighttime observations to a hand-written logbook in a similar fashion to the way I type my solar observations here. I also keep a list of all the deep sky objects I have found over the years. It doesn't matter whether it is solar, lunar, planetary, or deep sky. I write it down! I learn more that way!
Has thanked: 2885 times
Been thanked: 1094 times
Post by Montana » Thu Jan 14, 2021 4:16 pm
Very interesting report and also about your night time observations too :hamster:
Post by DeepSolar64 » Thu Jan 14, 2021 5:10 pm
Thank you Alexandra.
