February 16 2021 Observations
- Has thanked: 2147 times
- Been thanked: 1990 times
Session time is Noon to 12:45pm EST local time ( US ). The skies are partly cloudy with below average seeing. The temperature is 37F.
Coronado SolarMax II 60DS. 16x and 22x ( Ha )
I see two easy filaments in the SW quadrant of the disc. With a bit more difficulty I can see four other filaments in the SE quadrant. I can see three prominences on the limb. Two in the NE and a faint one in the SE.
The mottles are visible across the disc but are a bit soft on contrast today.
Orion 70mm Solar Telescope. 25x ( WL )
Blank disc. No detail.
Last night I got a Windows 8.1 machine up and running and loaded SharpCap and Registax 6 on it as well as the ZWO drivers and software for my ZWO ASI178MM monochrome camera. Now to make a shroud for the computer and prepare to start imaging to supplement my visual work. Hopefully now it will be soon. I just need time and warmer sunny weather to start playing with it. It does have a USB3 port so runs the camera smoothly.
Carpe Diem!
Carpe Diem!
- Has thanked: 3528 times
- Been thanked: 1460 times
Re: February 16 2021 Observations
Thanks for the report James! Glad you got some sun, it is quiet apart from the prominences at the moment. Good to hear you starting to fire up the camera, for years I just used a cardboard box as a light shroud for my laptop
I was thinking of a cardboard box or plastic tote.marktownley wrote: ↑Tue Feb 16, 2021 7:12 pmThanks for the report James! Glad you got some sun, it is quiet apart from the prominences at the moment. Good to hear you starting to fire up the camera, for years I just used a cardboard box as a light shroud for my laptop![]()
- Been thanked: 1386 times
Thanks for the report James.
Win 8.1 is well-good for the imaging and looking forward to see your results.
- Stardust5858
- Has thanked: 194 times
- Been thanked: 220 times
Great James, look forward to seeing your images.
Lunt 60mm Double Stack.
80ed +Baader K-Line.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
12inch OO Newtonian.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Has thanked: 10 times
- Been thanked: 675 times
Thanks for the update James
Hope the imaging comes together without too many hiccups
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
8' Diameter Dome
Thanks for the imaging encouragement everyone. The whole bit seems a bit complex and bewildering to me but I am gonna give it a whirl. I don't intend to stop my visual sessions here but would like to be able to re-enforce my work more with my own images and not relying on GONG and SDO imagery so much, though I will always find those useful. I admire the beautiful work of the fine imagers we have here and I wonder how I will ever fit in with such a skilled crowd.
I did hook the ZWO camera up to the laptop for a short time today at the end of my session and inserted it into the blocking diagonal. It came to focus the best I could tell but the sun had found the trees and high clouds had found the sun so my view wasn't a good one. Next to capture an image. Do a video. Stack images. Whew I have a lot to learn. It is nice to know that I am in good company of a bunch of skilled individuals.
- Has thanked: 2194 times
- Been thanked: 1617 times
Hi James,
Well done. Have not been able to open the roof of my Observatory as all day long we have winds up to 60 km/h ...
My weather here has been poor over the last couple of weeks too. It's really slowed down my observations. You have high winds and I have ice forecast for tonight.
- Has thanked: 3295 times
- Been thanked: 1263 times
Well done James
I would recommend loading up FireCapture (for acquisition), Autostakkert 3 for stacking and ImPPG for sharpening. You need to give all the software a try and pick which one you like best
I have Autostakkert3 already loaded but I still need to load/install Firecapture and ImPPG. I also need to install GIMP on my laptop. I still have work to do.
Thanks for the suggestions Alexandra.
