Belated FD image from 12th February 2021
- Stardust5858
- Has thanked: 194 times
- Been thanked: 220 times
Hi all, sorry for the belated post for imaging on the 12th February. Autostakker3 kept on crashing my laptop and when I did get it all running it stacked with strange artifacts. Anyway better late than never, lol. Lunt 60ds, 178mm Zwo ASI camera. 80ed +Baader-Cak K-Line and Hershal wedge.
- 20210212-1401UTellabryant-1col.thumb.png.db880e075cf03ca9f35ad7de6975e866.png (1.07 MiB) Viewed 174 times
- 20210212-1401UTellabryant-1.thumb.png.073a17f34bfee2ade52fc9da40ed4f1b.png (555.79 KiB) Viewed 174 times
- 20210212-1442UTelabryant-baader-K-line-col.thumb.png.19b815a6bd6cfe3f1e2eef99bd1c2404.png (1.19 MiB) Viewed 174 times
- 20210212-1442UTelabryant-baader-K-line.thumb.png.f4b387c6e34ee359d369646429d098b4.png (606.54 KiB) Viewed 174 times
Lunt 60mm Double Stack.
80ed +Baader K-Line.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
12inch OO Newtonian.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Has thanked: 3528 times
- Been thanked: 1460 times
Re: Belated FD image from 12th February 2021
Nice belated images Nigella! You might want to try stopping the ED80 down to 50mm to give an even cleaner disk, scopes always work better stopped down at these short wavelengths.
- Stardust5858
Thanks Mark, I'll give it a go, if/when I see the sun again, lol.marktownley wrote: ↑Tue Feb 16, 2021 10:35 pmNice belated images Nigella! You might want to try stopping the ED80 down to 50mm to give an even cleaner disk, scopes always work better stopped down at these short wavelengths.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Has thanked: 10 times
- Been thanked: 675 times
Hi Nigella...
Certainly worth the wait...very sharp set of images
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
8' Diameter Dome
- Stardust5858
Thanks Brian, appreciate your comments. Processing was a challenge to say the least, lol.MapleRidge wrote: ↑Tue Feb 16, 2021 11:24 pmHi Nigella...
Certainly worth the wait...very sharp set of images![]()
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Stardust5858
Just added an inverted hydrogen alpha emmision line image from the 12th February.
- PSX_20210216_235700.jpg (252.21 KiB) Viewed 148 times
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Been thanked: 1386 times
Hi Nigella, well worth waiting for these excellent set of images.
I too have had to stop-down my ED80 last year with its' HW, but only took a couple of images before the Sun went too-low from my observatory.
I have refitted that scope between the Lunt 60mm Ha and Cal-K scopes on the mount - ready for a restart of imaging very shortly and a play with the 50mm or 60mm stop-downs to see which is the best. (I have already prepared the f-stop disks).
Can i ask which platform your computer is using ??
In any case if that happens again, see if you can get a download of an earlier version as AS2, as I have several versions available of AS and not had any problems on my WIN-7, Win8.1 machines. You can have more than one version installed to choose from on a single PC.. I do also have a Win-10 PC, but there are problems with that machine, which will be sorted in due course by my IT guy - whenever...
Thanks for sharing
Thanks for sharing
I like the colouring of your images and especially the one you have just posted - well done
- Stardust5858
Thanks Terry, never had a problem with Autostakker3 before, so it's strange. I'm running a win10 i3 laptop so should have been OK. I'll take a look to see if I can get hold of an AS2 copy.. I'm getting a dedicated mini pc for the solar RoR already ordered so I don't have to lump the laptop around. Hopefully that'll be more up to date, lol.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Thanks Nigella.
I also have the same problem, where a computer (not laptop) is installed in the observatory and for winter imaging in WL, will be done using my Revolution R2 Imaging System, which is a viewing and recording-system, which only requires a portable 7" monitor, like you not wanting to take a large-screen laptop to and from.
This way, I can transfer the images via an SD-card Mini Digital video Recorder to either a large-screen laptop or ultra-large screens' computer in the observatory. That system can also be used for Lunar, Planetary and Deep-Sky imaging using my ETX-125-EQ-mount. This will be from a new mini-observatory - elsewhere in my large garden - to be built/erected in the Summer.
Best Wishes
Best Wishes
- Has thanked: 2147 times
- Been thanked: 1990 times
Nigella,
You have done beautifully with these. I'll have to install Autostakkert on my Windows 8.1 laptop. I hope it doesn't crash. Now if I can only learn to do beautiful images like you do. It looks a bit bewildering to me. But I will certainly try it. I have skills at visual astronomy but am very limited in knowledge in imaging.
- Stardust5858
Thanks James, appreciate your comment. You'll master the learning curve, I'm all self taught so if I can do it anyone can, lol. Be lovely when you're posting those images. Imaging is a good way to record your observations, I love it.DeepSolar64 wrote: ↑Wed Feb 17, 2021 5:33 amNigella,
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Has thanked: 1039 times
- Been thanked: 553 times
These turned out really well, Nigella. I love the detail.
- Stardust5858
Thanks Franco, appreciate your comment.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Has thanked: 3295 times
- Been thanked: 1263 times
These are all gorgeous, you make such an effort to get the colouring and processing just right
- Stardust5858
Thanks Alexandra, your comments are most appreciated, I only follow in your light.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Has thanked: 1388 times
- Been thanked: 1222 times
Nicely done, Nigella.
- Stardust5858
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Has thanked: 73 times
- Been thanked: 161 times
Beautiful images in both wavelengths! Thanks for sharing.
Arne
Arne
