18-2-2021-Thursday THE SPOTS AND MORE...
- Been thanked: 1386 times
Well at last Wednesday/17th produced a small-change in the sleep-pattern of our Sun over the past two weeks or so. SDO shows these...
The two new, but little Sun-spots have developed very-slightly over the last 10-hours, as the two images show and their cropped-versions...
Noticeably, also now there are more significant proms on the east-side of the limb - occurring at midnight-ish on Wednesday into Thursday, so hopefully there will be images of such - weather permitting...
The STEREO image is showing that there is a significant AR crossing the border at datum, so hopefully the North will show more action over the coming days...
Thanks for reading and viewing.
- 17-2-2021 2335z euvi_195_heliographic.jpg (46.38 KiB) Viewed 92 times
- 17-2-2021 2339z latest_512_0304.jpg (59.09 KiB) Viewed 92 times
- 17-2-2021 2329z latest_512_HMII-cr.jpg (511 Bytes) Viewed 92 times
- 17-2-2021 1423z latest_512_HMII (1)cr.jpg (457 Bytes) Viewed 92 times
- 17-2-2021 2329z latest_512_HMII.jpg (28.28 KiB) Viewed 92 times
- 17-2-2021 1423z latest_512_HMII (1).jpg (28.32 KiB) Viewed 92 times
- Stardust5858
- Has thanked: 194 times
- Been thanked: 220 times
Re: 18-2-2021-Thursday THE SPOTS AND MORE...
Thanks Terry, much appreciated.
Lunt 60mm Double Stack.
80ed +Baader K-Line.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
12inch OO Newtonian.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Has thanked: 3528 times
- Been thanked: 1460 times
Thanks Terry! Hoping for some sunshine this afternoon after the weather comes through this morning, be keen to see what is coming around the limb and how this small region in the north develops.
The latest imagery from SDO, shows that at the N.E. Limb and just becoming visible is another AR that may well have a spot or more.
Also the N.W. Quadrant pair of spots is still shown in the attached image at mid-day Thursday.
- 18-1-2021 1200z latest_512_HMII.jpg (16.91 KiB) Viewed 66 times
- Stardust5858
Thanks Terry, I managed to catch both today, quite a bright AR on the N.E. limb and the N.W quadrant spot/s. Probably process tomorrow. Quick pic added, lol.
- IMG_20210218_132217.jpg (1.23 MiB) Viewed 54 times
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
Hi Nigella, it certainly seems as if you have a well-good and interesting capture there on the screen.
Will be excellent to see the processed image - when you can.
Thanks for sharing.
Thanks for sharing.
- Has thanked: 3295 times
- Been thanked: 1263 times
Thanks for the info Terry, just cloud here ready for the weekend
Hi Alexandra, yes there is a very large "Low pressure" region over the Atlantic bringing-up from the S.W. so much of that cloud - up through the U.K.
Not much sign of that changing for the weekend for many areas here - either.
https://zoom.earth/#view=47.4,-0.2,4z/d ... crosshairs shows the same as a satellite image..
Hopefully at least the proms will become more active and AR2803 will also remain active and image-available after the white-fluffy has passed.
- PPVA89.jpg (214.36 KiB) Viewed 20 times
