To continue my thoughts, prepare, and minimise domestic backlash I decided to get up. At first light I was out fiddling and tinkering and an hour or so later the issue with the mount has been fixed. It's been frustrating me all week trying to solve it, but it is sorted now and should last that way for a while. In the meantime, a weather front was passing over and behind a gap of clearer air.
I started off getting a full disk with the 50mm double stack on the solarquest:
Conditions were painful though, and the seeing was all over the place, so don't look too close!
I was more interested in playing with my latest acquisition, a pre-Meade SM90 etalon to double stack my SM90ii scope. I've got a tilt tuner on the way, but even without the TT it was fun to play, and also very pleasing to see that minimal tilt will be needed to throw the ghosts. I spent quite a bit of time doing visual, and found myself chuckling away at how I could up the magnification to what i'm used to of old with my 40mm and 50mm double stack combos. The time just zipped past in between the passing clouds, my neighbour at the back came out and watched from a distance, we talked about later in the year when things are covid safe he would bring his kids round for a look.
Then, as with all things solar, the things you don't expect come up and blind side you. I switched back to the solarquest mount, the SM40 (40mm f10) ota and the Cemax 2x barlow with the home brew CaK filter and FLIR GH3 91S6M camera. The incredibly transparent air (seeing was a different matter) behind the passing Atlantic weather front is where CaK excels, and it was only when I looked at what i'd captured that I smiled. The spicule ring is visible all the way round the sun, along with proms and the surge from the new active region on the northern limb. Make sure you double click for the full size view...
If i'm lucky, I might get some more sun on sunday, till then the weather returns. Hope you like!
