19/20-2-2021 2200z AR2803 HAS TWO SMALL SPOTS
EGRAY_OBSERVATORY
Been thanked: 1386 times
Post by EGRAY_OBSERVATORY » Fri Feb 19, 2021 10:49 pm
SDO imagery confirms that there are currently two small spots on AR2803 at the N.E.Limb at datum.
No other reports available today...
19-2-2021 PM-z latest_512_HMII.jpg (28.27 KiB) Viewed 70 times
EGRAY_OBSERVATORY
Re: 19/20-2-2021 2200z AR2803 HAS TWO SMALL SPOTS
Post by EGRAY_OBSERVATORY » Fri Feb 19, 2021 11:05 pm
Another close-up of AR2803 is attached
Has thanked: 3528 times
Been thanked: 1460 times
Post by marktownley » Sat Feb 20, 2021 10:07 am
Thanks Terry. Spaceweather reports B-class activity from this area.
EGRAY_OBSERVATORY
Post by EGRAY_OBSERVATORY » Sat Feb 20, 2021 12:07 pm
That's sounds correct Mark as this region has been flaring much over the last few days...
Not grand, but "Beggars can't be choosers" - I guess.
Has thanked: 3295 times
Been thanked: 1263 times
Post by Montana » Sat Feb 20, 2021 4:54 pm
Thanks Terry! the weather is awful today, much worse than forecast :(
EGRAY_OBSERVATORY
Post by EGRAY_OBSERVATORY » Sat Feb 20, 2021 10:12 pm
Thanks Alexandra and yes I have been watching your weather on satellite-imagery.
This morning here it was sunny, but by the time I had completed the power-supply wiring for the ETX-125, Revolution R2 Imager and DVR, the haze-layer and cloud prevented a first-light test outside. At least it is now ready to try outside when the clouds allow...
I did have a quick peep through the Zoomable WL Spotting-scope where I could barely see the spots - before that haze-layer spoilt the seeing.
Stardust5858
Has thanked: 194 times
Been thanked: 220 times
Post by Stardust5858 » Sat Feb 20, 2021 10:17 pm
Thanks Terry for the update. Just catching up.
Lunt 60mm Double Stack.
80ed +Baader K-Line.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
12inch OO Newtonian.
Nec6 Eq Mount.
