February 20 2021 Observations. More images!
- Has thanked: 2147 times
- Been thanked: 1990 times
Session time is 11:00am until 12:45pm EST local time ( US ). The skies are clear with poor seeing. The temperature is 39F.
Coronado SolarMax II 90 DS. 32x and 44.5x ( Ha )
The first think I notice after a little tweaking of the etalons is a filament in the SW near the limb. Also noticed three filaments in the SE near the limb as well. I also noticed a tiny filament within a small plage ( AR12803 ) in the NE and could also make out a tiny filament above it.
The stars of the day are two prominences on the NE limb. The southernmost one is large and easy though fine detail comes difficult with the seeing. The northernmost one is a detached wisp leaning southward and is a bit fainter than it's southern neighbor.
Celestron NexStar 102GT w/Altair wedge and 540nm filter. 50x ( WL )
I can make out two pores in AR12803 in the NE. The SDO continuum image shows three. I can also see the faculae containing them as well. I see no other detail on the solar disc in WL. I can't even make out the granulation in this seeing!
I have included a couple of captures from my ZWO camera. The proms picked up well but I could only barely get a filament on the disc. I seem to have more trouble focusing and tuning using the camera than with the eye.
Seize the Sun!
Seize the Sun!
- Been thanked: 1386 times
Re: February 20 2021 Observations. More images!
Hi James,
Your capture 00008 & 9, are much better than the previous post.
Try sharpening a little for 9 as that is a probability for improvement.
I like the colouring of both and the proms is well-good and certainly as good, if not better than the Gong image. You might choose to flip the 9 image
to match the Gong image, but no probs there...
I'm following the spots situation on AR2803, as there does seem to be a third spot.
Thanks for the info and efforts.
Correction to my previous ---
" You might choose to flip the 8 image to match the Gong image, but no probs there..."
Thanks Terry. I am glad that they are detailed enough for you to tell my orientation is off a bit. The proms are flipped correct but need to be rotated up a bit I think.
I'll get there. I hope.
Yes James I should have correctly said "rotated" so we both now know - thanks.
You are doing very well.
Thank you Terry.
- Has thanked: 3528 times
- Been thanked: 1460 times
Great report and pictures James!
- Stardust5858
- Has thanked: 194 times
- Been thanked: 220 times
Thanks James for the report and your second light image's, it's not easy but you'll get there.
Lunt 60mm Double Stack.
80ed +Baader K-Line.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
12inch OO Newtonian.
Nec6 Eq Mount.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
Nec6 Eq Mount.
- Has thanked: 102 times
- Been thanked: 205 times
Did you purchase your coronado new from a vendor, or used from a classified ad?
Could you snap a photo of the filter in the nose of your blocking filter and post it here? Can use your cellphone and email it to yourself if you do not have a point and shoot.
Coronado was notorious for having faulty blocking filters that make imaging more difficult, so it is best to discover this now.
On your next imaging session, please post a comparison of your single stacked mode, disconnect the double stack filter, tune your rear etalon until the surface detail snaps into view on your computer screen. It should be very vivid, if it is not there may be an issue with your blocking filter.
, When your single stack image becomes very detailed on screen, add your double stack filter for a second photo se we can determine if you have a "sick" coronado. Realistically the double stack filter is going to make everything not as bright, and thus more difficult to image with if the sky is hazy.
You are certainly progressing, but i feel that you may be battling with a dirty sky or dirty blocking filter.
- Has thanked: 3295 times
- Been thanked: 1263 times
A lovely report James and great to see the images progressing, the prom image is great
the surface still needs a bit of work, I'm guessing this is single stack? a double stack is dimmer but much easier to pick out contrast and focus.
Congrats on the SPOD James.
Terrific start to your imaging..
I had a bit of a first light today, with the ETX-125 and an Orion Glass WL filter, as well as a Lunt HW.. Success from the visual-side, so I have little doubt that to do the imaging-side with the R2, should be successful.
I achieve a successful (preferably with some spots in WL), I can work-out the measurements required for the mini-observatory for this set-up...
Justapictureposter,
I'll have to photograph the BF for you and see what you think. I don't think it's the BF though. Looking at it I see no sign of discoloration and the filter is less than a year old. On the bright side I have two Coronado scopes so I have two blocking filters. One thing I have been battling lately is terrible seeing!
Alexandra,
I think the surface image was in single stack. I seem to have more trouble focusing on the disc than on the prominences. I try to tune visually before using the camera but if I try to adjust the tuning with the camera in I have difficulties.
Terry,
I am glad you got to observe today. I just now realized that I had the SPOD. Thank you!
Alexandra,
Terry,
- Has thanked: 71 times
- Been thanked: 100 times
Well done James - as a non imager I have great respect for the progress you have made. One day soon I will follow in your footsteps.....
Thanks HM. But here on SolarChat I walk in the footsteps of giants.Highbury Mark wrote: ↑Sun Feb 21, 2021 9:24 pmWell done James - as a non imager I have great respect for the progress you have made. One day soon I will follow in your footsteps.....
Thanks HM. But here on SolarChat I walk in the footsteps of giants.DeepSolar64 wrote: ↑Sun Feb 21, 2021 9:36 pm[quote="Highbury Mark" post_id=281982 time=<a href="tel:1613942669">1613942669</a> user_id=6746]
[/quote]
Indeed! The best.
- Has thanked: 10 times
- Been thanked: 675 times
Hi James...
Awesome to see your images to go along with the reports
Image quality will improve with practice, but off to a great start!
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
8' Diameter Dome
Thanks Brian. I seem to do better on proms than the disc itself.MapleRidge wrote: ↑Sun Feb 21, 2021 10:28 pmHi James...
Awesome to see your images to go along with the reports![]()
All,
I feel like Zefram Cochrane ( Star Trek ) when he invented the warp drive for Earth. The planet then was able to join the interstellar community and experience " first contact ".
The ZWO drive lets me formally join the SolarChat imaging community!
Live long and prosper!
