A nice clear day here today, with some clouds managing to drift through part way through my imaging session. I should have went out a little sooner I guess
The prom and new AR on the NE limb was the most impressive view through the LS80T as well as the dark filament in the SW. The image below is a composite of separate disk and limb exposures with the limb inverted. This was imaged with the LS80T/LS75FHa/B1800Ha solar scope and the ASI174MM camera: The new activity in the NE held promise for some WL and CaK details, so the iStar 150mm, f8 OTA was used with the Lunt WL wedge and CaK Wedge/B1800CaK/Baader K-Line filters for these full disk images (dust spots included). The ASI1600MM was used for these: I changed the iStar over to Ha with the pair of DSII etalons and B1800Ha blocker with a 3x focal extender ahead of the ASI174MM. The clouds started to drift in during these captures forcing some long delays between images. The seeing also degraded quiet a bit which didn't help my attempts to image the areas of interest in higher resolution.
AR2803 on the NE limb was the prime target, and the largest proms was on the limb nearby: I made a slight adjustment to the tuner and found this filament pop into view in the AR: Before I gave into the clouds I got an image of the filament in the SW: This covers the images for today's session. As always, questions and comment are always welcome.
