- fc2_save_2021-02-21-130954-0000ed2.jpg (270.18 KiB) Viewed 134 times
over the hill prom with edmund 2 inch scope
- Has thanked: 3497 times
- Been thanked: 1447 times
Re: over the hill prom with edmund 2 inch scope
That works really well John! Tell us more about the scope you made?
- Has thanked: 2108 times
- Been thanked: 1959 times
Nice!! You had far better luck than I did today.
- Been thanked: 128 times
mount rail and laser pointer mount rail added later in time
used combo qrk chromo for Ha
at F25 works real nice
- Has thanked: 10 times
- Been thanked: 672 times
Nice catch of the fila-prom!!!
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
8' Diameter Dome
im a crazy puppy
still have log of first use of this scope sept 4 1973
- Been thanked: 1385 times
Well John, a comment made recently on another post, said about "size doesn't matter" and your scope and the image shown here - really proves that. Almost difficult to believe that a 2" scope can achieve such a good image, but you have proved that too...
Thanks vm for sharing and congrats on the result.
John,
At F25 this scope should be as free of color as many modern apochromats. I am guessing that the focuser is 1.25". Back in the early 1970s many small refractors came with .965 focusers.
I started with a 50mm focal refractor back in 1978. Both it and my 1982 model 60mm Traq refractor both have .965 focusers. I still have my early logbooks I did using the 50mm as well. It's an F11.8.
That's a cool scope John!
- krakatoa1883
- Has thanked: 80 times
- Been thanked: 279 times
Fine scope and image. I know that book (All about telescopes) full of interesting projects. At that time I was using a 60 mm refractor.
Raf
yes no color error detected at f25
since body was home build i chose 1.25
there is a CA chart that plots CA based on
F vs Diameter it only goes up to F20!
anything > 5 is considered good
this scope is 12.5
nothing on chart is that high
this scope is 12.5
- Has thanked: 3260 times
- Been thanked: 1249 times
That's a super filaprom and the sketch from 1973 made me smile
well done!
