February 21 2021. Calm Sun.
- Has thanked: 2105 times
- Been thanked: 1959 times
Session time is 11:00am until 12:30pm EDT local time ( US ). The skies are partly cloudy with below average seeing. The temperature is 45F.
Coronado SolarMax II 60DS. 16x and 21.5x ( Ha )
Detail today came difficult. There isn't much to be seen. First off I notice two prominences on the solar limb. One in the NE and another easier one in the SW. The one in the SW is a part of a filament so is a filaprom! That is the only filament I can see on the disc. I can see the plage of AR12803 in the NE as a mere disturbance in the spicule field. Not exactly easy. The spicule mottling covers the disc but the contrast is low.
I can only see one small pore in the NE. It's associated with AR12803. I cannot see it's faculae today. The solar granulation can only be hinted at.
I did get one not-so-good image of the mottling of the disc in Ha. No other details.
Carpe Cerevisi!
Carpe Cerevisi!
- Has thanked: 10 times
- Been thanked: 672 times
Re: February 21 2021. Calm Sun.
Good to see your report for today James!
Your WL image turned out well...not sure if the Ha image needed better tuning, but I'd expect to see the AR or filament. Still good to work up the leaning curve
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
8' Diameter Dome
- Been thanked: 1385 times
Thanks James for your report and the Ha image could do with a tad more adjustment, but well done on the efforts..
There wasn't much more than the mottles to image on today's disc. My goal is to image filaments like Rainer does!
Thanks Brian and Terry.
- Has thanked: 3497 times
- Been thanked: 1446 times
Thanks James, looking at the Ha image it isn't on band which is why you're not seeing the filaments...
- Has thanked: 3260 times
- Been thanked: 1249 times
I think the filament blew away according to Spaceweather so I think you missed it. I am sure many more will come along so that you can test your tuning. Lovely report and keep up the imaging
Thanks for the comments everyone! I am under rain today so no sun for me.
James, when you get some sunshine put only the single stack on the scope. Put the camera in, focus, and tune the etalon with the laptop facing you and keep turning the tuning until you see maximum surface contrast on the screen which will be the darkest setting. Check GONG to see if there is a good filament to really look for. When you have done that, place the DS on. This time start tuning and you will find you get maximum brightness (yes the opposite) and the filament will really pop out 3D. Then you will have a good imaging session.
It is much easier to tune with the camera on as you can stand by the etalon and just watch the screen changing.
Let us knowhow you get on.
Thank you Alexandra. I may be keeping the screen too bright and I start with the DS on. I am going about it all backwards. Nothing unusual for me! ~laughing~. Thanks for the tips. I'll try it.
Alexandra,Montana wrote: ↑Mon Feb 22, 2021 3:52 pmJames, when you get some sunshine put only the single stack on the scope. Put the camera in, focus, and tune the etalon with the laptop facing you and keep turning the tuning until you see maximum surface contrast on the screen which will be the darkest setting. Check GONG to see if there is a good filament to really look for. When you have done that, place the DS on. This time start tuning and you will find you get maximum brightness (yes the opposite) and the filament will really pop out 3D. Then you will have a good imaging session.
I tried single stack today ( 2-24-21 ) and got much better discs, including filaments and active regions. Thank you very much!
