Imaging setups. 2-19, 20, 21 2021
- Has thanked: 2105 times
- Been thanked: 1959 times
Here are the imaging setups I used on Friday 2-19, Saturday 2-20 and Sunday 2-21. It's certainly gonna be a work in progress. A better light shroud for the computer and tracking mounts for the scopes are in the plans. After that a CaK filter and Binoviewer for visual use. Then maybe a Sodium D line Quark. Last a larger refractor ,127mm or bigger, for white light and nighttime use.
I intend to keep visual observing as my primary solar observing method using imaging only to back it.
- Been thanked: 1385 times
- Has thanked: 231 times
- Been thanked: 34 times
Re: Imaging setups. 2-19, 20, 21 2021
Thanks James.
Call me Geoff.
- Has thanked: 1020 times
- Been thanked: 543 times
Very nice set up James. Good seeing you yesterday on zoom.
- Has thanked: 91 times
- Been thanked: 185 times
- Has thanked: 3497 times
- Been thanked: 1446 times
Looks good!
Just giving everyone an idea what I was using.
- Has thanked: 2159 times
- Been thanked: 1584 times
Hi James,
Look great and the next step as you said an equatorial mount and then a fixed observatory with a Roll Off Roof = ROR
- Has thanked: 3260 times
- Been thanked: 1249 times
Heck Yeah!!!!
You will see how comfortable it will be specially when getting older and now it is the time to do it.
Go out, push the roof away and ready to go ...
Believe me ...
Keep up the good work James and along with your usual reports will make you a Super Solar reporter...
- Has thanked: 10 times
- Been thanked: 672 times
Nice observing kit James !!!
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
8' Diameter Dome
No more lugging everything out and back in again. That sounds so good.rsfoto wrote: ↑Mon Feb 22, 2021 9:28 pmYou will see how comfortable it will be specially when getting older and now it is the time to do it.
Believe me ...
