Today's SUN (20210222) | LUNT152 images
pedro
Has thanked: 3 times
Been thanked: 1091 times
Post by pedro » Mon Feb 22, 2021 8:39 pm
WEB LINK:
http://pedroreastrophotography.com/sun_ ... 21-02.html
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
SUN (20210222) H-alpha (10:00 UTC). LUNT152, SM90II, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M, two-pane mosaic
SUN (20210222) H-alpha (10:00 UTC). LUNT152, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M, two-pane mosaic
SUN (20210222) H-alpha PROMS (10:00 UTC). LUNT152, BF30, X2 Barlow (@X1.4), PGR GRASSHOPPER 3 GS3-U3-28S5M
SUN (20210222) H-alpha (10:00 UTC). LUNT152, BF30, X2 Barlow (@X1.4), PGR GRASSHOPPER 3 GS3-U3-28S5M
SUN (20210222) H-alpha PROMS (09:30 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210222) H-alpha PROMS (09:30 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210222) CaK PROMS (09:30 UTC). TV101 F/5.4, LUNT 1200 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210222) WL, CaK & H-alpha (09:30 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4
Has thanked: 3384 times
Been thanked: 1380 times
Re: Today's SUN (20210222) | LUNT152 images
Post by marktownley » Mon Feb 22, 2021 8:43 pm
A great set Pedro! There's that badly behaved SM90ii again ;)
Stardust5858
Has thanked: 184 times
Been thanked: 198 times
Post by Stardust5858 » Mon Feb 22, 2021 8:59 pm
Great captures Pedro, thanks for sharing.
Lunt 60mm Double Stack.
80ed +Baader K-Line.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
12inch OO Newtonian.
Nec6 Eq Mount.
dhkaiser
Has thanked: 761 times
Been thanked: 697 times
Post by dhkaiser » Mon Feb 22, 2021 9:11 pm
Well done Pedro.
Dan
Lunt LS60THa, Lunt LS60FHa DS
Lunt 102mm ED, William Optics ZS73, Herschel Wedge
Celestron C6 SCT
Ioptron AZ Pro mount, CG-4 mount
ASI 178 mono
South central Indiana
USA
justapictureposter
Has thanked: 85 times
Been thanked: 166 times
Post by justapictureposter » Mon Feb 22, 2021 10:02 pm
have you tried an experiment with a different blocking filter on your Sm90II. From my experience with coronado parts, they are truly reliant on this factor. If your blocking filter is not matched to the etalon you get exactly this problem.
How does your BF30 look when you point it at a white lamp?
Here are three examples of coronado blockers.
pst BF5 red
coronado bf5 red.jpg (41.09 KiB) Viewed 174 times
pst bf5 orange
coronado bf5 orange.jpg (29.65 KiB) Viewed 174 times
coronado BF15 dark orange
coronado bf15 orange.jpg (23.98 KiB) Viewed 174 times
EGRAY_OBSERVATORY
Been thanked: 1384 times
Post by EGRAY_OBSERVATORY » Mon Feb 22, 2021 10:04 pm
Excellent set of images and presentation Pedro.
Thanks vm for sharing
pedro
Post by pedro » Mon Feb 22, 2021 11:51 pm
I have a BF15 that was matched to the SM90II by Oliver Smie (Beloptik). I used the BF30 today though
Has thanked: 1004 times
Been thanked: 533 times
Post by ffellah » Tue Feb 23, 2021 1:14 am
A great series, Pedro, but the large prom is the money shot today.
Franco :bow
Has thanked: 10 times
Been thanked: 664 times
Post by MapleRidge » Tue Feb 23, 2021 3:43 am
As always, a treat to see your excellent images Pedro...well done :bow
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
Has thanked: 2052 times
Been thanked: 1923 times
Post by DeepSolar64 » Tue Feb 23, 2021 6:06 am
They all look great to me. Including the one through the SMII90 etalon. Pedro, that's the one you had Meade to work on and had someone else to work on as well, right? I remember you mentioning it in the Zoom meeting.
You probably have more of a discerning eye than I do.
pedro
Post by pedro » Tue Feb 23, 2021 8:33 am
Thanks again guys
The SM90II was sent twice to the Meade factory and once to Oliver Smie (Beloptik). According to Oliver it is now on band but it still lacks contrast and definition. I guess it is still OK for visual though
Has thanked: 3159 times
Been thanked: 1219 times
Post by Montana » Tue Feb 23, 2021 9:04 am
Wow!! the huge prominence is a beauty :hamster: :bow a great set Pedro apart from the SM90, it is so off band you can't even see the AR in the south, that is more than a little 'lacking contrast' ;)
pedro
Post by pedro » Tue Feb 23, 2021 10:09 am
I agree Alexandra
I will use it from now on only for double stacking
SUN (20201226) H-alpha. LUNT152, DS SM90II, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M - example with bad seeing
SUN (20201217) H-alpha. LUNT152, SS/DS SM90II, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M - again with bad seeing
Post by marktownley » Tue Feb 23, 2021 8:17 pm
It definitely works well with the 152 as a double stack, but as a single stack that 90 is not on band, regardless of what Oliver says. Still, at least you know it does have a use in double stack mode, not quite a complete paperweight...
