Full disk 22-02-2021
rsfoto
Has thanked: 2194 times
Been thanked: 1617 times
Post by rsfoto » Mon Feb 22, 2021 9:35 pm
... and ¡ YESSS ! there they are the new spots AR 12804 ? and AR 12805 ?, not yet numbered in the https://www.swpc.noaa.gov/products/solar-region-summary
Here todays discs in H-alpha and finally White Light again.
Interesting surface pattern in the Soutwestern quadrant. Looka like a lot of tufts of grass.
dhkaiser
Has thanked: 783 times
Been thanked: 703 times
Re: Full disk 22-02-2021
Post by dhkaiser » Mon Feb 22, 2021 10:03 pm
Two new sunspot groups and a filaprom, super Rainer.
Dan
Lunt LS60THa, Lunt LS60FHa DS
Lunt 102mm ED, William Optics ZS73, Herschel Wedge
Celestron C6 SCT
Ioptron AZ Pro mount, CG-4 mount
ASI 178 mono
South central Indiana
USA
EGRAY_OBSERVATORY
Been thanked: 1386 times
Post by EGRAY_OBSERVATORY » Mon Feb 22, 2021 10:07 pm
Excellent images of the two AR.s and the activity in the N.E. too, plus the proms.
Thanks for sharing
Has thanked: 3528 times
Been thanked: 1460 times
Post by marktownley » Mon Feb 22, 2021 11:01 pm
These are stunners Rainer!
Stardust5858
Has thanked: 194 times
Been thanked: 220 times
Post by Stardust5858 » Mon Feb 22, 2021 11:20 pm
Lovely Rainer, thanks for sharing.
Lunt 60mm Double Stack.
80ed +Baader K-Line.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
12inch OO Newtonian.
Nec6 Eq Mount.
Has thanked: 1039 times
Been thanked: 553 times
Post by ffellah » Tue Feb 23, 2021 1:16 am
Top images Rainer
Has thanked: 10 times
Been thanked: 675 times
Post by MapleRidge » Tue Feb 23, 2021 3:40 am
These are excellent FD Ha and WL images Rainer...well done :bow
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
Has thanked: 2147 times
Been thanked: 1990 times
Post by DeepSolar64 » Tue Feb 23, 2021 5:47 am
I second that!
Has thanked: 3295 times
Been thanked: 1263 times
Post by Montana » Tue Feb 23, 2021 8:35 am
Ah! so beautiful Rainer :bow :hamster: I agree, the southern hemi looks like a field of long grass blowing in the wind. Also of note, the spot groups in the WL are virtually a mirror image of each other in the north and south. They are at the same latitude and also nearly the same longitude too. If you flipped the Sun 180 degrees you would see the same picture :)
