... and ¡ YESSS ! there they are the new spots AR 12804 ? and AR 12805 ?, not yet numbered in the https://www.swpc.noaa.gov/products/solar-region-summary
Here todays discs in H-alpha and finally White Light again.
Interesting surface pattern in the Soutwestern quadrant. Looka like a lot of tufts of grass.
Full disk 22-02-2021
- Has thanked: 9710 times
- Been thanked: 5769 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: Full disk 22-02-2021
Two new sunspot groups and a filaprom, super Rainer.
Dan
South central Indiana
USA
USA
Excellent images of the two AR.s and the activity in the N.E. too, plus the proms.
Thanks for sharing
Thanks for sharing
- Has thanked: 20779 times
- Been thanked: 10462 times
These are stunners Rainer!
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely Rainer, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9307 times
- Been thanked: 6144 times
- Been thanked: 4422 times
These are excellent FD Ha and WL images Rainer...well done
- Has thanked: 17845 times
- Been thanked: 16977 times
I second that!
- Has thanked: 17970 times
- Been thanked: 8905 times
Ah! so beautiful Rainer I agree, the southern hemi looks like a field of long grass blowing in the wind. Also of note, the spot groups in the WL are virtually a mirror image of each other in the north and south. They are at the same latitude and also nearly the same longitude too. If you flipped the Sun 180 degrees you would see the same picture
