Today's Solar Features in High Res & Wide Field | Mega Thread | Feb 23rd 2021
MalVeauX
Has thanked: 436 times
Been thanked: 406 times
Post by MalVeauX » Tue Feb 23, 2021 6:39 pm
Hey all,
I finally got a morning with minimal clouds, and fairly good weather. It's been dreadful for months. Seeing was decent, not supreme, but quite good, getting into sub-arc-second seeing all morning and averaging a few peaks in the 0.8 arc-second range which allowed some higher resolution attempts. I didn't get to the maximum of the potential of the aperture, but was getting decent data at least which is better than I've had in a while with the storm conditions. I left the high res stuff soft processing wise. The big prominence field is gorgeous. The AR's are crackling with small flares and activity, some were so fast they changed in moments while watching.
Colored:
B&W:
Seeing Conditions (decent, getting sub-arc-second often enough, most images were around 0.8 arc-seconds):
Equipment:
C8 Edge + Full 214mm D-ERF + Baader Red CCD-IR Block Filter (2nd D-ERF) + PST etalon + 10mm BF + ASI290MM
++ As above, minus the etalon and BF for the photosphere imaging
100mm F10 masked Refractor + Baader Red CCD-IR Block Filter (2nd D-ERF) + PST etalon + 10mm BF + ASI290MM
60mm F16.7 masked Refractor Baader Blue CCD-IR Block Filter (2nd D-ERF) + Lunt Cak & Altain Astro 395nm + IMX253 (discs)
rsfoto
Has thanked: 2194 times
Been thanked: 1617 times
Re: Today's Solar Features in High Res & Wide Field | Mega Thread | Feb 23rd 2021
Post by rsfoto » Tue Feb 23, 2021 6:44 pm
Hi Marty,
Well done
dhkaiser
Has thanked: 783 times
Been thanked: 703 times
Post by dhkaiser » Tue Feb 23, 2021 6:48 pm
Super set Marty!
Dan
Lunt LS60THa, Lunt LS60FHa DS
Lunt 102mm ED, William Optics ZS73, Herschel Wedge
Celestron C6 SCT
Ioptron AZ Pro mount, CG-4 mount
ASI 178 mono
South central Indiana
USA
Has thanked: 1039 times
Been thanked: 553 times
Post by ffellah » Tue Feb 23, 2021 6:50 pm
Top shots, Marty, thank you for sharing them.
Martin_S
Has thanked: 121 times
Been thanked: 386 times
Post by Martin_S » Tue Feb 23, 2021 7:14 pm
Excellent presentation Marty, well done.
Martin
H - alpha setup
Lunt LS60THa Tilt-Tuned Solar Telescope, LS50FHa solar filter front-mounted Double stack etalon. 2 x Barlow
Remote etalon and focusing control's ASI290mm Camera
White Light setup
Skywatcher ED72 ,180 MAK,ND3.8 full aperture filter Homemade solar wedge, IR cut filter, Solar Continuum filter.
AZEQ5 Pro mount.
Darkside setup
Skywatcher ED72 , GSO RC6. Celestron Evolution mount
Has thanked: 3528 times
Been thanked: 1460 times
Post by marktownley » Tue Feb 23, 2021 8:34 pm
A very impressive collection Marty, glad you got to use the 200mm!
Has thanked: 2147 times
Been thanked: 1990 times
Post by DeepSolar64 » Tue Feb 23, 2021 10:03 pm
WoW Marty. You take the prize on these. That big prom reminds me of a furry animal nose down feeding on the spicule grass with a tail out behind it.
All of these are superb. You have the sun covered today!
Has thanked: 10 times
Been thanked: 675 times
Post by MapleRidge » Wed Feb 24, 2021 12:08 am
Outstanding work there Marty...well done :bow
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
JochenM
Has thanked: 382 times
Been thanked: 722 times
Post by JochenM » Wed Feb 24, 2021 5:34 am
Well, looks like you certainly took advantage of the opportunity. Impressive amount of very good images there, Marty.
Has thanked: 1388 times
Been thanked: 1222 times
Post by Carbon60 » Wed Feb 24, 2021 9:24 am
You've been busy in the better weather, Marty. A really great set of images.
Has thanked: 3295 times
Been thanked: 1263 times
Post by Montana » Wed Feb 24, 2021 6:35 pm
Superb Marty!! :bow :bow :hamster:
Stardust5858
Has thanked: 194 times
Been thanked: 220 times
Post by Stardust5858 » Wed Feb 24, 2021 7:15 pm
Fantastic captures Marty, thanks for sharing.
Lunt 60mm Double Stack.
80ed +Baader K-Line.
Solarquest Mount.
2.7m Pulsar Dome.
70mm Achromatic.
12inch OO Newtonian.
Nec6 Eq Mount.
arnedanielsen
Has thanked: 73 times
Been thanked: 161 times
Post by arnedanielsen » Wed Feb 24, 2021 7:49 pm
Lovely high-res images, Marty!
Arne
