Solar Images from Daystar Gemini
- Has thanked: 1075 times
- Been thanked: 1986 times
Hello everyone, i probably should have joined this forum ages ago. Here are some images that I would like to share.
Taken using a Daystar Gemini (in Chrom mode) on Nov 25 2020 - Sky-Watcher Esprit 150
3rd Image is White Light using a Baader 2" Herschel Wedge
- Has thanked: 17853 times
- Been thanked: 16996 times
Re: Solar Images from Daystar Gemini
WoW!!!! Stunning!! I love the furry look the Ha images have. Is the other one a white light image?
- Been thanked: 10489 times
Top shots Simon!
Very nice WL image too!
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Welcome Simon, thanks for sharing your image's.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Yes the Esprit 150, the camera used is the ASI174MM - Im gonna be replacing it soon as its been dropped several times, has spots all over the place and has seen better days.justapictureposter wrote: ↑Thu Feb 25, 2021 6:33 pm the 150mm espirit presumably? nice rig.
What camera?
- JochenM
- Been thanked: 1619 times
Welcome to SolarChat, Simon.
I've seen your images pass through my Instagram feed every now and then (assuming you're the same Simon ); great work!
- Been thanked: 4427 times
Welcome Simon, and these are very impressive images
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
Amazing!
- Has thanked: 9319 times
- Been thanked: 6157 times
Wow!!! a very warm welcome Simon simply stunning
Do you have any dates, times, names of the active regions? are these recent or past?
This is AR12786 (larger spot) taken ion November 25 2020. No idea of the time but probably around 10am PST
- Has thanked: 6305 times
- Been thanked: 7324 times
Wonderful images, Simon! Welcome to SolarChat and thanks for sharing!
Arne
Arne
