I only noticed it when I imaged on this side of the sun. The internal Baader filter, or maybe the tilt adapter?
How do I remove it or reduce it? More tilt?
Thanks!
What is causing this?
- Has thanked: 60 times
- Been thanked: 78 times
- Has thanked: 141 times
- Been thanked: 240 times
Re: What is causing this?
Love to know myself.
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- Has thanked: 8543 times
- Been thanked: 8280 times
Reflections such as this can often be eliminated adding a circular polarising filter, or tilting the reflecting surface. You just need to find out what’s causing the problem....trial and error I’m afraid.
- Has thanked: 20783 times
- Been thanked: 10462 times
It's case of systematic elimination. Rotate various components in the optical train until you find the culprit, then when we know which one it is can work out a solution.
- Has thanked: 17970 times
- Been thanked: 8905 times
Definitely a reflection because you have the exposure set so high. I also get this but managed to reduce it a lot by adding black card inside my nosepiece of the camera.
Thanks guys.
I have flocking paper inside the nosepiece, but maybe I should cover everything inside the camera.
Clear sunny skies!
Chris
Lunt LS50THa
Lunt "Luntair" Altair 102ED
Chris
Lunt LS50THa
Alexandra,
What do mean by a black card in the nosepiece of the camera?
Jack
Jack
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
Family dinner on Sunday, but I made it home before the sun set behind the house. I removed the Baader filter, that did nothing. I flocked the camera and eyepiece. That knocked down the worst of it, but there was still a faint glow left behind. Taped over every gap in the system, no difference.
Any other suggestions or do I just have to live with the faint glow?
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
