24-3-2021 AR 2806, 2811, 2812 ???
EGRAY_OBSERVATORY
Been thanked: 1677 times
Post by EGRAY_OBSERVATORY »
Sunspot regions today 24-3-2021
Region / Number of sunspots / Class
2806 7 AXX ???
2811 5 BXI
2812 1 HSX
2810 without spots
SDO doesn't agree with those figures though ???
Has thanked: 2696 times
Been thanked: 2363 times
Re: 24-3-2021 AR 2806, 2811, 2812 ???
Post by DeepSolar64 »
SDO shows it “ As it is “...
rsfoto
Has thanked: 2533 times
Been thanked: 1903 times
Post by rsfoto »
Hi Terry,
Can you point me to some literature about the " Class " of a Sun spot ?
Thank you Rainer
Stardust5858
Has thanked: 312 times
Been thanked: 379 times
Post by Stardust5858 »
Thanks Terry for the report, managed an imaging session this morning.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Nec6 Eq Mount.
Stardust5858 wrote: Wed Mar 24, 2021 3:38 pm Thanks Terry for the report, managed an imaging session this morning.
We're waiting....
Has thanked: 4060 times
Been thanked: 1781 times
Thanks for the update Terry, very late day at work today, I may try and aim for an early finish tomorrow as recompense in attempt of some early evening solar...
EGRAY_OBSERVATORY
Thanks everyone and hopefully will see your images whenever you can Nigella and James
Hi Rainer, https://www.spaceweatherlive.com/en/solar-activity.html is the website I've been using for a while (along with many others), where
the web-linked one shown above, was and still is showing the inclusion of AR2806 with its' 7-spots. I suspect someone there has accidentally included this for whatever reason as the current SDO image at around 2300hrs/24-3-2021 is only showing a total of 4 (or so) spots with AR2811/2812.
I tried checking backwards before 8-3-2021 with my records when AR2806 was around, suggests to me that 2806 is being recorded as a possible return-visit, but certainly not with as many as 7-spots now for itself...
Any other comments welcome.
Within that web-link, where within the "Sunspot Regions" panel further information as "Class Magn. & Spot" of - the question-mark can explain more.
How accurate these two items are:- may or may not be accurate, so I don't tend to utilise those...
SDO is usually very up-to-date (within 30+ minutes of a required-datum and shows enough of what is happening as far as I am concerned...
Rainer I trust that may answer your question ?
Regards
24-3-2021 2300+z latest_512_HMII.jpg (27.93 KiB) Viewed 65 times
EGRAY_OBSERVATORY
https://hinode.msfc.nasa.gov/data_archive.html & https://www.lmsal.com/heksearch/ may well provide more intense-data about what is occurring at present and previously on our Sun...
Cheers & Enjoy getting your head around the websites... !!!
eroel
Been thanked: 1340 times
Post by eroel »
Terry:
Thanks for the info and the images.
EGRAY_OBSERVATORY
Thanks again Eric. Still strange that 2806 has been included on that website, but hey who knows...
See if Rainer can work his magic...
MAURITS
Has thanked: 151 times
Been thanked: 343 times
Post by MAURITS »
Thanks for the update Terry.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 3769 times
Been thanked: 1497 times
Great info Terry, thanks :hamster:
EGRAY_OBSERVATORY
Thanks Mark, Maurits and Alexandra.
That AR2806 overlap-error has now been deleted and 2811 appears to be degrading at mid-day today.
