PST Mod fergling
AndiesHandyHandies
Has thanked: 708 times
Been thanked: 238 times
PST Mod fergling
Post by AndiesHandyHandies »
A sunny, scudding clouds and windy day. Blowing the Rumak180 about. Fortunately my 'meat machine' imaging processing algorithm was up to viewing.
Tried out my little bino-viewers first. Saw some RSPhoto quality surface details.
In the 5x could see the whole Sun and quite bright and contrasty.
Realised I am missing a pair of 8x out my set of eyepieces which might be a good magnification.
I just bodged the 1.5A Omega Bobs filter used as a blocker in a tilter at maximum angle to start with. Had a play with it from there to flat and back.
Moved over to the 25mm Clave'. Eventually came to the conclusion maximum tilt was OK.
I tried the CPL and crossed-polarisers. I have seperated the re-collimating lens from the etalon and I had the idea to slide the CPL adapted to a 48mm filter ring into the back PST adapter then held in by the 2" diagonal nose piece with the re-collimator in a plastic Celestron/SW moon filter adapted to it with a Blue Lighting 48mm to 28.5 mm adapter.
A big improvement and no major of axis disks. Still a small close by reflection, I assume off the etalon. And some diffuse circular features now.
Nice view of the one large prom which looked like a chromosome with a fuzzy bit next to it.
Interesting to compare the Rumak180 PST mod to the 90mm with Quark Prom next time the seeing is better.
Cheers. Andrew.
Has thanked: 4060 times
Been thanked: 1781 times
Re: PST Mod fergling
Sounds like you were having fun Andrew!
MAURITS
Has thanked: 151 times
Been thanked: 343 times
Post by MAURITS »
Nice to read.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
AndiesHandyHandies
Re: PST Mod fergling Log Stardate 2021/03/29
Scudding clouds, sun and wind. Not for nothing is the nearby road junction is called 'Windy Gap'.
Having played with the blocking filter tilt I have a miasma.
Going to the full posiible tilt without the adjusters falling out washed out the details.
So somewhere there must be an optimum over-lap.
Need a good day to tilt and clock the blocker to get the best result.
I could see the large proms with nice brightness and contrast.
Cheers. Andrew.
Has thanked: 3769 times
Been thanked: 1497 times
Glad you had a good view of the proms Andrew :hamster:
AndiesHandyHandies
Had a play trying different tilts of the blocking filter.
And all combinations of polarisers.
Got rid of the miasma.
Just a little off axis faint reflection I assume off the etalon. And one faint one half way off, possibly off back of etalon and then blocker.
Nirvana I think now.
Cheers. Andrew.
