Ca K solar disk image, March 25, single and double stack - ASI1600
christian viladrich
Been thanked: 306 times
Post by christian viladrich »
This is my first solar images of the season and the first light of my ASI 1600.
Here is the single stack image :
http://www.astrosurf.com/viladrich/astr ... SI1600.jpg
And the double stack image :
By comparison, the single stack image looks a bit "flat".
Best regards
Christian
Bob Yoesle
Has thanked: 44 times
Been thanked: 124 times
Re: Ca K solar disk image, March 25, single and double stack - ASI1600
Post by Bob Yoesle »
Lovely full disc's Christian.
The DS is clearly superior to the SS...
eroel
Been thanked: 1341 times
Post by eroel »
Christian:
Super FD´s, but the DS is superior.
Best regards.
rsfoto
Has thanked: 2533 times
Been thanked: 1905 times
Post by rsfoto »
Hi Christian,
Excellent and huge discs. What is the focal length ?
Has thanked: 3785 times
Been thanked: 1498 times
Superb!! I too vote for the double stack :bow :hamster:
christian viladrich
Thanks to all :-)
Yes indeed, the double stack is clearly better. I was a little bit surprise by this diffence since the Alluxa filter is 0.40 nm FWHM (and not 0.44 nm). This is probably because it is a multi-cavity filter. The exposure time is still reasonnable thanks to the UV sensitivity of the ASI 1600.
The image is taken at the native focus of the TOA 1500 (about 1100 mm). The sensor and pixel sizes are perfect. No need for mosaic. This is just one-shot picture (with a stack of 7 frames).
Next step is triple stacking, just like Pedro in Ha ... No, just joking ;-)
Has thanked: 1264 times
Been thanked: 689 times
Post by ffellah »
Beautiful results, Christian. The DS is better but the SS is excellent too.
krakatoa1883
Has thanked: 110 times
Been thanked: 364 times
Post by krakatoa1883 »
christian viladrich wrote: Thu Mar 25, 2021 8:58 pmBy comparison, the single stack image looks a bit "flat".
I would be very happy of such a flatness in my CaK discs.... :lol:
Raf
Has thanked: 10 times
Been thanked: 801 times
Post by MapleRidge »
These are superb Christian :bow
The single stack looks fabulous and would be impressive on its own...now the DS version is a step beyond!!!
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
Celestron CR-150 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
Bob Yoesle
I'd give it a shot Christian !-)
MAURITS
Has thanked: 151 times
Been thanked: 343 times
Post by MAURITS »
Excellent images Christian.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
christian viladrich
Thanks Franco, Brian, Raf and Maurits :-)
christian viladrich
Bob Yoesle wrote: Sat Mar 27, 2021 11:00 am
Hi Bob, I remember that one. It was quite a teaser for us :-)
BTW, I checked the transmission profiles of the Barr and Alluxa filters : the Barr filter is a two-cavity filter while the Alluxa filter is a three-cavity. This would be equivalent to a five-stacked system is the FWHM of both filters was similar.
Bob Yoesle
Pretty cool Christian. Any chance you can get a hold of a Coronado PST and/or Lunt CaK filters to see what they look like? The only thing I've ever seen regarding them (I assume they are very similar) is shown below, and it's not too informative:
Lunt CaK Etalon_wide blocking filter.PNG (42.79 KiB) Viewed 106 times
Has thanked: 4060 times
Been thanked: 1781 times
Very nice disks Christian. Have you experimented with tilting the filters in the DS? Your images are hinting at the spicule rings, i've found this is what 'pops out' when the tuning of the filters is spot on.
christian viladrich
Hello Mark,
The EO394 is mounted in a tilt-system. Tilting this filter is only for rejecting reflexions away from the main image.
The Alluxa filter is mounted in another tilt-system. The setting of the tilting is relatively straigtforward. The idea is to minimize banding.
Prominences are very faint, so there are not very usefull in my case, but this is certainly a good idea in other cases.
The Barr filter is a bit shifted to the blue, so no need to tilt it.
Just for the fun, here is what the chromospheric fringe looks like :
http://astrosurf.com/viladrich/astro/so ... 00-ddp.jpg
It a bit tricky with this configuration to display the disk and the prominences on the same image .
