Lunt 60 Triple Stack
Has thanked: 1682 times
Been thanked: 1525 times
Post by Carbon60 »
I finally bought myself another front etalon for my Lunt 60. This gives me the option to double stack with the new one, or triple stack with the new and the old one together. Coupled with the recently purchased Coronado BF15 the views are phenomenal. Tuning wasn't too bad, requiring only a few moments of tweaking and clocking to avoid artefacts.
Here are the results on a Basler acA2440-75um fitted with a 1.5x Barlow (two pane mosaics, heavily overlapped as the disk just fails to fit onto the sensor).
The quadrant was captured on a Basler acA1920-155um with 2.5X Barlow.
First up is the little monster....
ImageLunt 60 Triple Stack by Stuart Green, on Flickr
Two pane FDs in mono and colour.....
Image20210327_Ha_TS_FD_2Mosaic_Mono by Stuart Green, on Flickr
Image20210327_Ha_TS_FD_2Mosaic_colour by Stuart Green, on Flickr
and the quadrant views of the main regions, AR2811 & AR2812.
Image20210327_Ha_Quadrant_TS by Stuart Green, on Flickr
Image20210327_Ha_Quadrant_TS_Colour by Stuart Green, on Flickr
I'm VERY pleased with the final results of this setup. Ha FDs have been my nemesis for some time now.
Thanks for looking.
Has thanked: 3785 times
Been thanked: 1497 times
Re: Lunt 60 Triple Stack
Great results Stuart :bow :hamster: I'm glad to see you happy :hamster:
Astrophil
Been thanked: 316 times
Post by Astrophil »
Well Stu, you made that look easy. Great contrast, details, and nice even illumination across the disk. A winner!
Phil
MAURITS
Has thanked: 151 times
Been thanked: 343 times
Post by MAURITS »
Great result Stu and what a beautiful setup.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
solarnoob
Has thanked: 25 times
Been thanked: 52 times
Post by solarnoob »
Nice looking setup and great results.
Frank
Lunt LS50Ha, LS100Ha
ZWO ASI174
Sky-watcher Solarquest mount
Bob Yoesle
Has thanked: 44 times
Been thanked: 124 times
Post by Bob Yoesle »
Hi Stu, those are wonderfully uniform FD images! And the scope is awesome looking.
I'm curious. With my DS Tucson SM90s I have generally found having the tilt-wheels (and therefore tilt angles) 180 degrees apart seems to work best. What "clock setting" orientation do you have for your Lunt front etalons?
christian viladrich
Been thanked: 306 times
Post by christian viladrich »
Excellent ! There are a lot of small size low contrast filaments filament visible here and there.
The view should be great at the eypiece.
Martin_S
Has thanked: 144 times
Been thanked: 483 times
Post by Martin_S »
Great post Stu ,what capture settings are you using for a triple stack setup?.
Martin
H - alpha setup
Lunt LS60THa Tilt-Tuned Solar Telescope, LS50FHa solar filter front-mounted Double stack etalon. 2 x Barlow
Remote etalon and focusing control's ASI290mm Camera
White Light setup
Skywatcher ED72 ,100 f/10 Achromat Homemade solar wedge, IR cut filter, #58 green filter.
AZEQ5 Pro mount.
Darkside setup
Skywatcher ED72AZGTi mount , GSO RC6. Celestron Evolution mount
torsinadoc
Has thanked: 165 times
Been thanked: 82 times
Post by torsinadoc »
Wonder full disc. Did you need an adapter to stack the two front mounted etalons?
EGRAY_OBSERVATORY
Been thanked: 1679 times
Post by EGRAY_OBSERVATORY »
Hi Stu,
That's an interesting set-up with the two DS's, but I'm slightly confused (not that it is difficult for me), but can you confirm please - if your four images were taken with both the DS's, which I assume they are ?
If so, would it be possible to take some images (weather permitting-as usual) with the single DS and the Double DS on your Lunt 60PS.
Bearing in mind that I have the Lunt 60 Ha (non PS) and a DS, it could help me to see what difference I could expect for a similar arrangement that you have shown here...
Many thanks
rcwinter
Has thanked: 64 times
Been thanked: 91 times
Post by rcwinter »
Excellent images and setup, works really well
Congrats A1
:bow2
Baader DERF 90 & 160. Vixen ED114SS, Takahashi TOA130, Daystar Quantum SE .4ang, SolaREDi .7 ang module, Coronado Solarmax 60, ZWO ASI 174MM. 1600MM, 178MM
rsfoto
Has thanked: 2533 times
Been thanked: 1905 times
Post by rsfoto »
Hi Stu,
Excellent contrast gain you have.
arnedanielsen
Has thanked: 100 times
Been thanked: 223 times
Post by arnedanielsen »
Great work Stuart! Sharp and very natural looking contrast.
Arne
Has thanked: 2696 times
Been thanked: 2365 times
Post by DeepSolar64 »
Very nice work Stu. The images are sharper than I would have expected for all that glass. Nice contrast!
Post by Carbon60 »
Bob Yoesle wrote: Sat Mar 27, 2021 3:49 pm Hi Stu, those are wonderfully uniform FD images! And the scope is awesome looking.
Hi Bob,
Thanks for your comments. This was my first effort with this setup, so I was just happy to get something out of it that looked okay (no internal reflections etc), so clocking was a little ad hock, I must say.....and with the threat of cloud cover looming I was just grateful to get some Sun time under my belt. I think a more rigorous approach will follow as I get into the swing of this and I'll note the positions more accurately. Gravity also plays a part in that the etalons are pulled (tipped) towards the ground as the threads are loosened (small deviations have a large effect, as we know), so I think the whole thing will change with tracking. I might look into making some form of front mounted stabilisation clamp to get control of this.
Post by Carbon60 »
Martin_S wrote: Sat Mar 27, 2021 8:39 pm Great post Stu ,what capture settings are you using for a triple stack setup?.
Martin
Many thanks, Martin.
The exposure was 11 ms for the triple stack, with just a little gain added. This is just a tad over double that for double stacking (5 ms).
Post by Carbon60 »
torsinadoc wrote: Sat Mar 27, 2021 9:02 pm Wonder full disc. Did you need an adapter to stack the two front mounted etalons?
No adapter required. The etalons have the same thread front and rear, so they just screw together.
Post by Carbon60 »
EGRAY_OBSERVATORY wrote: Sat Mar 27, 2021 9:03 pm Hi Stu,
Many thanks
Hi Terry,
No problem. As you might imagine, I ran both double and triple stacking on the day (triple stacking comprises the internal pressure tuned etalon and two front mounted etalons, as shown in the first photo). Here's a comparison. These comparisons are tricky because etalons have to be retuned/rotated and the capture settings adjusted between the two configurations and there's always that nagging question about how true the comparison can be with all of these 'tweaks'. Anyhow, I tried to optimise for each case. Scudding clouds didn't help...
20210327_Ha_Triple vs Double.jpg (1.88 MiB) Viewed 179 times
You should be able to see some extra details in the triple stacked image.
pedro
Has thanked: 4 times
Been thanked: 1321 times
Post by pedro »
Wonderful results Stu and a perfect even disk with your triple stack LUNT60. You have a winner combo
Has thanked: 4060 times
Been thanked: 1781 times
You've got an excellent combo there that works very well. Good DS TS comparison. Might be worth the experiment of changing the order of the external etalons when time allows and seeing if there is any difference.
Martin_S
Post by Martin_S »
Carbon60 wrote: Sun Mar 28, 2021 6:48 am
Martin
Thanks Stu, have you experimented with binning your camera? and comparing the exposure times.
Martin
H - alpha setup
White Light setup
AZEQ5 Pro mount.
Darkside setup
Has thanked: 1264 times
Been thanked: 688 times
Post by ffellah »
You definitely tamed your nemesis, Stu :D . Great set up and top images there.
viewer
Oh, I get it now!
Oh, I get it now!
Has thanked: 61 times
Been thanked: 3 times
Post by viewer »
Very nice indeed! Could TS be the new normal for the disk?
Reminds me why I'm primarily observing prominences with my single stack... :D
Balcony, EQ-2, PST single stack, 8-24 zoom, Mak102 Skywatcher with erecting diagonal, filter Baader
Sketches:
https://www.cloudynights.com/gallery/me ... 07-viewer/
Post by Carbon60 »
Martin_S wrote: Sun Mar 28, 2021 10:36 am
Martin
Martin
Hi Martin, Good suggestion. No, I haven't tried this yet, but I think the exposure time is quite reasonable.
