CaK Full Disk and Polar Jets - 27th March
Has thanked: 4060 times
Been thanked: 1781 times
Hi All!
The weekend weather was forecast to be poor apart from a brief spell just after sunrise, it's a situation i'm all too familiar with in spring with the rising temperatures, clouds just bubble up not long after the sun comes up... I checked meteoblue which was saying seeing of 3", however I thought i'd try the 60mm at f16, i'm glad I did as the seeing was quite a bit better than this with quite a stable image on the screen, maybe 1.5" i'd estimate. Transparency was good in a sky filling rapidly with clouds growing in size rapidly scudding past and I only managed to get 2 short captures before it was completely clouded out, fortunately this was all I needed for the full disk.
Calcium is going to be my pet project this year, and phase 1 is establishing tuning of the filters using a skybender to get them on band. I've found when this is the case the spicules and proms are quite easy to see. This is the case with this disk, and is most definitely worth double clicking for a look full size in your favourite chroma. In particular if you look around the northern polar region (one o'clock position) you can see how the spicule jets diverge away from the suns magnetic north pole following the field lines.
ImageCaK-FD-Polar-jets-bw by Mark Townley, on Flickr
ImageCaK-FD-Polar-jets-blue by Mark Townley, on Flickr
ImageCaK-FD-Polar-jets-sdo-red by Mark Townley, on Flickr
And the Solar Dynamics Observatory image from the same time. No spicules or jets there, NASA should get themselves on solarchat, we could save them a whole load of money and improve their data :lol:
Imagelatest_4096_1700 by Mark Townley, on Flickr
Hope everyone has had a good weekend.
Stardust5858
Has thanked: 312 times
Been thanked: 379 times
Re: CaK Full Disk and Polar Jets - 27th March
Post by Stardust5858 »
Thanks Mark, lovely captures and wonderful you were able to get these. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Nec6 Eq Mount.
MAURITS
Has thanked: 151 times
Been thanked: 343 times
Post by MAURITS »
Great clean and crisp captures Mark.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Alto
Has thanked: 241 times
Been thanked: 42 times
Post by Alto »
Great ones Mark.
( I was all go for a session yesterday morning, clear blue skies. Hit the sun first time ( well top left of sensor on a 174 ). From then on it was downhill with problems of network, scope connecting then failing, focuser connecting then failing. Cloud bubbled and closed the blue for the afternoon.... Sheesh! I'm trying an Ascom re-install for a cure I hope! )
Call me Geoff.
Alto
Post by Alto »
p.s. You said Polar Jets, was expecting you to be having 'problems' with them on Earth...............
Call me Geoff.
Alto wrote: Sun Mar 28, 2021 10:51 am p.s. You said Polar Jets, was expecting you to be having 'problems' with them on Earth...............
Ha ha ha! Can see how it could be taken :lol:
Thanks everyone for the kind comments :)
Has thanked: 1264 times
Been thanked: 686 times
Post by ffellah »
These turned out great Mark: first time I see spicules in CaK.
Has thanked: 3769 times
Been thanked: 1497 times
The spicule layer is indeed phenomenal Mark :bow :hamster: and I like the rose colour too, you did a much better job than me. I must work on my colour :)
Has thanked: 2696 times
Been thanked: 2363 times
Post by DeepSolar64 »
Mark,
These CaK images are stunning! Among the best I have seen. While the SDO AIA 1700 image shows the supergranulation as yours does it does not show the spicules at all! The disc is also more uniform and better lit in yours. Impressive work. you have kicked SDO's ass!!
And I so want an CaK module. I would use it on my AT72EDII and my C102. I can use the ASI178MM camera to see and image it now.
James :bow
krakatoa1883
Has thanked: 110 times
Been thanked: 364 times
Post by krakatoa1883 »
Superb detail, Mark, with such a small aperture. Great disc.
Raf
robert
Has thanked: 1 time
Been thanked: 203 times
Post by robert »
Astonishing Mark... :o :o :shock:
Robert
2021 images https://tinyurl.com/d7jbz3sw
2020 images https://tinyurl.com/v6muwvm
christian viladrich
Been thanked: 306 times
Post by christian viladrich »
Excellent Mark !!
EGRAY_OBSERVATORY
Been thanked: 1677 times
Post by EGRAY_OBSERVATORY »
Excellent captures Mark and processing/colours too.
Thanks for sharing
EGRAY_OBSERVATORY
As Alto referred to "Polar Jets" too, don't even go there Mark, as have had enough problems diagnosing a scenario with a General Aviation aircraft and its' electrical-system today, so your heading rang a bell - so to speak... !!!
Has thanked: 1682 times
Been thanked: 1525 times
Post by Carbon60 »
Superb images, Mark. Just when you think things can’t get any better.......
It really is amazing how our hobby has developed in recent years.
Thanks everyone for your kind comments!
Carbon60 wrote: Mon Mar 29, 2021 6:21 am It really is amazing how our hobby has developed in recent years.
Indeed Stu, here's my first CaK image from many years ago...
EGRAY_OBSERVATORY
I also must look through my archive material - as your Cak image shows what we could achieve "yonks" ago.
So Mark, Do you remember this one of yours posted on Spaceweather.com around 14-4-2010 ??
My first impression for naming the prom-image is "Mark's Creature from Outer-Space - Roasting on Our Sun" !!!
Truly an outstanding capture and processed/colouring Mark and you were 10-years younger then... !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Keep up the excellent captures and thanks for all your efforts too..
Regards
eroel
Been thanked: 1340 times
Post by eroel »
Mark:
Beautiful clean and crisp CaK images, also beautiful the one taken 10 years ago.
Thanks everyone, let's hope we get some mega proms like the one above soon!
JochenM
Has thanked: 482 times
Been thanked: 803 times
Post by JochenM »
Cracking shots, Mark.
Here's to more activity like above.
EGRAY_OBSERVATORY
Your wish is my command Mark, as SDO is showing another Monster Prom in the same quadrant this morning at 0929z...!!!
I might even get to image this myself...
Best Wishes too..
30-3-2021 0929z latest_512_0304.jpg (58.66 KiB) Viewed 37 times
