By the time I started observing after lunch there was a hazy sky but a still day.
RodAstro has made me a off-axis adapter to send a 10mm beam from the 90mm OWHY through the side of the Quark to avoid some mica damage causing scatter. All I have done is slip some Black3ed 180 Emery paper in the hole, rest bare alloy.
90mm F6.7 TS Triplet, Baader 35nm, Beloptik KG3, 3x Revelation long barlow, off-axis 10mm adapter, Baader 7nm, Quark Prominence, Baffle DS Black3 180 Emery over sector of mica damage, Clave 25mm.
With the Sun just out of the field I had a good view of todays large prom against a black background. Nice fine details. Also a long fine jet, from yesterday?
Tried the Vision King 3x TE but too much scatter, could just about detect the prom.
Perhaps I need a Baader TZ 3 or 4 now to start imaging proms with the above set up?
Cheers. Andrew.
Quark Prominence Fergling
- Has thanked: 702 times
- Been thanked: 236 times
Re: Quark Prominence Fergling
After a play with the PST mod I thought I would have a bit of fun with a third rate commercial filter.
Had a view of the bigish double prom in the off-axis arrangement, nice dark background.
Went back to full view with the mica damage baffle still and the proms looked just as bright, slightly more background light.
3.40 UT
9 for me the biggish prom. Action man figure with sword in lower hand and shield fanding off a large eagle with the other. A small bright below.
10.00 Little prom leaning down.
11.50 Jet spray with a dog leg up to a floating triangle.
Cheers. Andrew.
3.40 UT
Cheers. Andrew.
- Has thanked: 4057 times
- Been thanked: 1780 times
Lots of fun trying all the different combos!
