30-3-2021 A fairly bland Ha image of today.
EGRAY_OBSERVATORY
Been thanked: 1680 times
Post by EGRAY_OBSERVATORY »
Not much surface-detail in Ha today, as shown, so those proms have it...
2021-03-31 1041z 11_41_33_AS_p100_g2_ap4_conv.jpg (348.54 KiB) Viewed 57 times
2020-03-30 1054z Ha-proms Capture_00002-GAMMA.jpg (191.04 KiB) Viewed 57 times
Has thanked: 3785 times
Been thanked: 1498 times
Re: 30-3-2021 A fairly bland Ha image of today.
Nice one Terry!! :bow :hamster:
I popped out too and had a look, I'll process tonight while the hubby watches Top Gear (yawn)
JochenM
Has thanked: 482 times
Been thanked: 803 times
Post by JochenM »
The proms more than make up for it indeed. Nice work, Terry.
EGRAY_OBSERVATORY
Thank you so much Alexandra and Jochen for your kind words.
Also thanks to the SPOD organiser too !!
I'm starting at the beginning again with the two new cameras (ZWO ASI 178MM's) and the WL scope and camera will be activated tomorrow - if time allows.
Then I will be trying-out the various magnification-lenses next, then adding my filter-wheel to try-out just about every filter available that I already have, to see if I can achieve some of the images that others have achieved - so well... (using knowledge gained from SolarChat - of course)...
More learning-curves to be undertaken, before any Cataract op's to be done - hopefully.
Regards
Has thanked: 2696 times
Been thanked: 2365 times
Post by DeepSolar64 »
The disc doesn't show much for me either. I couple of small low contrast plages and a few small filaments. Proms saved the day!
EGRAY_OBSERVATORY
Yes that sounds right James and I probably could have adjusted the etalon a little more for such detail and also this morning was for Single-Stacking only, so the DS would likely have shown more SFC detail...
