Prom animation 30th March 2021
Has thanked: 1682 times
Been thanked: 1523 times
Post by Carbon60 »
Here's the large NW prom animated over a period of 35 minutes. I was going to run this thing over an hour, but the seeing conditions were worsening by the minute. You'll see quite some variation over the course of the sequence of images.
Captured on my 150mm/DS Lunt 35 using a Basler acA1920-155um camera and 2.5x Powermate.
72 frames in total. ImPPG alignment.
Image2021-03-30_T_09-27-20-0108_L_l5_ap1975_out_aligned by Stuart Green, on Flickr
Thanks for looking.
Has thanked: 2696 times
Been thanked: 2363 times
Re: Prom animation 30th March 2021
Post by DeepSolar64 »
Absolutely incredible! It looks alive!
christian viladrich
Been thanked: 305 times
Post by christian viladrich »
Splendid !!
AndiesHandyHandies
Has thanked: 708 times
Been thanked: 238 times
Post by AndiesHandyHandies »
Lovely animation.
Cheers. Andrew.
H-Alpha
Oh, I get it now!
Oh, I get it now!
Has thanked: 79 times
Been thanked: 33 times
Post by H-Alpha »
Fantastic Stuart!!! :bow
Thanks for sharing.
Can you please explain what "150mm/DS Lunt 35" is? DS is double stacking, I suppose with Lunt H-a? But what is 35? And what is your 150mm scope?
What would you say (in arc seconds) for your starting (amazing resolution) and ending seeing conditions?
Thanks once more,
Alexandros
Has thanked: 1256 times
Been thanked: 685 times
Post by ffellah »
Excellent animation work, Stu, you killed it !
solarnoob
Has thanked: 25 times
Been thanked: 52 times
Post by solarnoob »
Impressive tour de force! :bow
Frank
Lunt LS50Ha, LS100Ha
ZWO ASI174
Sky-watcher Solarquest mount
StarHugger
Oh, I get it now!
Oh, I get it now!
Has thanked: 395 times
Been thanked: 20 times
Post by StarHugger »
Awesome animation, Thanks for the close up look Stu.
Aaron
Aaron.
AJamesB
Has thanked: 305 times
Been thanked: 194 times
Post by AJamesB »
Fantastic, love the detail!
lunt ls100tha single stacked + hinode solar guider on skyview pro equitorial mount
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
Mind-Blowing when you think of how fast the plasma is actually moving. It would cross the Earth's size in mere seconds!
Has thanked: 3769 times
Been thanked: 1497 times
Absolutely terrific :hamster: :bow what time did you do your animation? it seems very similar to mine :)
Boso36
Has thanked: 49 times
Been thanked: 47 times
Post by Boso36 »
Fantastic work Stu!
I also got a lot of images from my Quark and 70mm refractor. I will try and process these in the coming days but am not an expert at them. It looked quite good, and I imaged and got lots of images for an hour. Not sure if the framing was all the same, as there was some drift, and variation over the hours.
Is a single video file any good ? It looked quite impressive where I was sitting.
Thanks.
Magnus
eroel
Been thanked: 1339 times
Post by eroel »
Stu:
Superb animation, thanks for sharing that splendid work.
Post by Carbon60 »
Montana wrote: Wed Mar 31, 2021 2:58 pm Absolutely terrific :hamster: :bow what time did you do your animation? it seems very similar to mine :)
Thanks Alexandra. I started at 8:27 UT.
Post by Carbon60 »
H-Alpha wrote: Tue Mar 30, 2021 11:32 pm Fantastic Stuart!!! :bow
Thanks for sharing.
Thanks once more,
Alexandros
Many thanks, Alexandros.
150 mm is the objective diameter. The Lunt 35 is a former Ha scope (35mm objective) no longer sold by Lunt. Yes DS means double stacked (two Lunt 35 etalons).
Has thanked: 4060 times
Been thanked: 1781 times
This is excellent Stu, glad you managed to capture it, work meant I missed it.
