Visual Report 31/03/2021
AndiesHandyHandies
Has thanked: 708 times
Been thanked: 238 times
Post by AndiesHandyHandies »
Rumak180 35nm Beloptik Omega 1.5A blocker PST CPL Bino-viewers 10X 23.2mm
12.45 UT
9.15 Blob over the surface, two legs? 2.30 on Gong.
11.50 Biggish prom 4.30 Gong
Fir tree leaning left. Arecebo dish on its left with dish horizontal pionting to tree.
Dark filament below on right going down to right. Dark then broken.
Small spray below them.
Below 2.00 I saw three dark patches in a flat triangle pointing up. 4 showing on Gong above 6.30.
Under 8.30 An oval with darl upper left and top. Below a circle with a centre. Showing under 2 on Gong.
Remove the CPL.
9.15 now a dumpy pyramid.
Under 8.30 the dark oval had bright spots under and over the top arch.
1.15 UT Clave' 25mm
Surface a lot brighter.
Jet at 2.30 still there from yesterday. 8.30 on Gong
12.15 Fine tall thin triangle leaning down.
6.30 Biggish proms. Fir tree leaning down with dumpy triangle, bigger feed on the left and finer one on the right.
7.00 Little pyramid.
9.00 Small pyramid with a spray over.
Cheers. Andrew.
EGRAY_OBSERVATORY
Been thanked: 1676 times
Re: Visual Report 31/03/2021
Post by EGRAY_OBSERVATORY »
Thank you Andrew, at least helps to see what I missed under the clouds today
Has thanked: 2696 times
Been thanked: 2363 times
Post by DeepSolar64 »
Thanks Andrew. I was clouded out today and could not do my own session.
Has thanked: 3769 times
Been thanked: 1497 times
Fantastic report, I wish I could have seen the Arecibo dish :) you have a great imagination :)
MAURITS
Has thanked: 151 times
Been thanked: 343 times
Post by MAURITS »
Thanks for the report Andrew.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
eroel
Been thanked: 1339 times
Post by eroel »
Andrew:
Thanks for the detailed report, I was clouded. :-(
Has thanked: 4060 times
Been thanked: 1781 times
Good report thanks Andrew
AndiesHandyHandies
Forgot to say when I went out looking up at the Sun not encouraged to see 10 buzzards circling up a thermal between me and the Sun! A buzz of buzzards?
And the day before the clouds were travelling with the prevailing westerlies but a cloud bank kept being replenished in front of the sun as the westerly wind encountered the pressure wave over the north-south ridge I am one.
Its not just palm trees are an issue!
Cheers. Andrew.
I see buzzards often here too! For a few in other places that might not know what a " buzzard " is, they might know them by another name. Vultures!
AndiesHandyHandies
Hi James,
We do not have vultures in the UK.
Small raptors.
Cheers. Andrew.
Has thanked: 1264 times
Been thanked: 685 times
Post by ffellah »
Thank you Andrew, for the detailed report.
I think in the USA you call buzzards, hawks? I think the Red tailed hawk is the most similar.
