Visual Report 31/03/2021
- Has thanked: 701 times
- Been thanked: 236 times
Rumak180 35nm Beloptik Omega 1.5A blocker PST CPL Bino-viewers 10X 23.2mm
12.45 UT
9.15 Blob over the surface, two legs? 2.30 on Gong.
11.50 Biggish prom 4.30 Gong
Fir tree leaning left. Arecebo dish on its left with dish horizontal pionting to tree.
Dark filament below on right going down to right. Dark then broken.
Small spray below them.
Below 2.00 I saw three dark patches in a flat triangle pointing up. 4 showing on Gong above 6.30.
Under 8.30 An oval with darl upper left and top. Below a circle with a centre. Showing under 2 on Gong.
Remove the CPL.
9.15 now a dumpy pyramid.
Under 8.30 the dark oval had bright spots under and over the top arch.
1.15 UT Clave' 25mm
Surface a lot brighter.
Jet at 2.30 still there from yesterday. 8.30 on Gong
12.15 Fine tall thin triangle leaning down.
6.30 Biggish proms. Fir tree leaning down with dumpy triangle, bigger feed on the left and finer one on the right.
7.00 Little pyramid.
9.00 Small pyramid with a spray over.
Cheers. Andrew.
12.45 UT
Remove the CPL.
1.15 UT Clave' 25mm
Cheers. Andrew.
- Been thanked: 1653 times
Re: Visual Report 31/03/2021
Thank you Andrew, at least helps to see what I missed under the clouds today
- Has thanked: 2654 times
- Been thanked: 2347 times
Thanks Andrew. I was clouded out today and could not do my own session.
- Has thanked: 3734 times
- Been thanked: 1490 times
Fantastic report, I wish I could have seen the Arecibo dish
you have a great imagination
- Has thanked: 148 times
- Been thanked: 336 times
- Been thanked: 1331 times
Andrew:
Thanks for the detailed report, I was clouded. :-(
- Has thanked: 4057 times
- Been thanked: 1780 times
Good report thanks Andrew
Forgot to say when I went out looking up at the Sun not encouraged to see 10 buzzards circling up a thermal between me and the Sun! A buzz of buzzards?
And the day before the clouds were travelling with the prevailing westerlies but a cloud bank kept being replenished in front of the sun as the westerly wind encountered the pressure wave over the north-south ridge I am one.
Its not just palm trees are an issue!
Cheers. Andrew.
Cheers. Andrew.
I see buzzards often here too! For a few in other places that might not know what a " buzzard " is, they might know them by another name. Vultures!
Hi James,
We do not have vultures in the UK.
Small raptors.
Cheers. Andrew.
Small raptors.
Cheers. Andrew.
- Has thanked: 1245 times
- Been thanked: 675 times
I think in the USA you call buzzards, hawks? I think the Red tailed hawk is the most similar.
