A few days ago I had a lot of misery to have a reasonable recording of the sun.
Seeing and transparency below all level.
So this is my only result after a lot of bad images processing.
150 mm refractor.
ASI 174MM camera and Interference Eliminator.
Quark Prominences.
A few days ago ...
- Has thanked: 2696 times
- Been thanked: 2363 times
Re: A few days ago ...
It looks good Maurits! I certainly battle seeing and transparency often.
- Been thanked: 1675 times
Under the circumstances you have certainly got a well-good image Maurits.
At least you can do some imaging, whereas today the observatory-computer decided to not fire-up beyond initialization prior to starting, so will have a further go tomorrow and awaiting my supplier to ask.
I might have to use another machine..
Thanks for sharing
Thanks for sharing
- Has thanked: 1262 times
- Been thanked: 685 times
I like your image Maurits. Sometimes the conditions are very frustrating, but you succeeded in getting one image.
- Stardust5858
- Has thanked: 312 times
- Been thanked: 379 times
Yeah, sometimes conditions are not ideal Maurits, but it's a good capture. Terry, hope you get your computer sorted.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Has thanked: 4060 times
- Been thanked: 1781 times
Looks good Maurits!
- Has thanked: 10 times
- Been thanked: 800 times
A very nice capture in the poor conditions Maurits...well done
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
Celestron CR-150 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
8' Diameter Dome
- Has thanked: 1682 times
- Been thanked: 1523 times
It can be so frustrating when you have all the equipment, skills and time to image, but the conditions just don't cooperate. You did really well here. Lovely image.
