Session time is 11:30am until 11:50am EDT local time ( US ). Skies are clear with fair seeing. The temperature out is 45F.
Coronado SolarMax II 60 DS. 16x, 21.5x and 33x ( Ha )
First off I notice a new plage in the NW quadrant of the disc. It's small but bright. I can see two spots within it and a dark filament that appears to be connecting them. Elsewhere on the disc I see two filaments in the far south and two more in the far north. I see a small prominence on the SW limb and another small prominence on the SE limb.
I see the mottles covering the disc easily today. I quickly found the details much more easily today unlike yesterday when I had to work to see nearly everything.
Orion 70mm Solar Telescope 25x and 50x ( WL )
I see two sunpots easily in the new plage today. The SW spot is a bit bigger than it's NE neighbor. I also see a patch of faculae in the SE.
The fine granulation of the solar disc is visible.
Off to see a friend in Rock Hill SC I go. My scopes are going with me.
April 3 2021 Observations
- Has thanked: 2696 times
- Been thanked: 2363 times
- Has thanked: 4060 times
- Been thanked: 1781 times
Re: April 3 2021 Observations
Nice report James, glad you got a session in. I had blue skies all afternoon today and had the scopes out too. Just processing the data.
- Been thanked: 1676 times
Thanks for the latest update James and seeing some spots too.
The temporary pc is up and running with all four cameras working, so hopefully just need some blue skies that I can steal from Mark T.
One of the cameras is the POLEMASTER...
Had to turn the Classical music up to drown the USB noises... Perhaps I should have turned the pc-volume down instead...
- Stardust5858
- Has thanked: 312 times
- Been thanked: 379 times
Thanks for the report James. I too had all scope's out this afternoon. HA, Ca-K and WL. Be a few days before I can process as it's the Easter hols, lol. Managed to see the small spots and new plage area. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Classical music!? Big thumbs up
on that, Terry!
Oh yes of course James - had to be done and heard...
Update, my IT guy (a previous PC engineer) is taking the H.P. away on Tuesday to initially see if it can be sorted and hopefully-before it might need to go back to the computer-supplier nearby for after 12-4-2021...
Cheers and I recall you are going on a trip, so have a safe journey. as well as hopefully CLEAR SKIES too...
Regards
Regards
- Has thanked: 10 times
- Been thanked: 800 times
Great report for your session James!
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
Celestron CR-150 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
8' Diameter Dome
Thanks for your replies and input everyone!
