4-4-2021 1st light this year - of my 3-lights FD's
EGRAY_OBSERVATORY
Been thanked: 1653 times
Post by EGRAY_OBSERVATORY »
Well it's been a bit hectic here in temporarily-resolving the observatory's faulty computer problem and replacing-it with a small-screen laptop, which itself is much more difficult to use, but at least allows now the three Solar-scopes to do what they are meant to do.
The computer is to be taken-away for examination as to its' start-up problem and maybe away for a while - unless hopefully a simple snag... :?:
This afternoon the sky turned crystal-blue with no haze or the normal clouds, but was a little turbulent though... :hamster:
This allowed plenty of time to make final adjustments to the WL ORION ED80T-CF scope - which had been taken down for cleaning (although the objective cannot be easily removed, so still not perfect - by far... :band No F-stops now required as a Polariser is now in front of the mono-
Altair GPCAM :bow
As expected the two Lunt-scopes performed very-well and now I am able to capture the 3-lights in one session. :band
There may be more to do with imaging-results, as I am unable to use the two large-monitors with this small laptop, so apologies if not as good as could be. Finally I hope to start using the many Barlows soon to get some close-up's...
Enjoy
4-4-2021 1329z Cal-K proms.jpg (302.01 KiB) Viewed 92 times
4-4-2021 1328z Calcium-K.jpg (748.58 KiB) Viewed 92 times
4-4-2021 1331z Calcium-K.jpg (732.53 KiB) Viewed 92 times
4-4-2-21 1309z Ha-Proms.jpg (514.91 KiB) Viewed 92 times
4-4-2021 1309z Ha FD.jpg (1.81 MiB) Viewed 92 times
4-4-2021 1258Z x100 AR2813.jpg (83.77 KiB) Viewed 92 times
4-4-2021 1255z WL+HW+Polar+GPCAM-AR2813.jpg (90.98 KiB) Viewed 92 times
SDO latest_512_0304.jpg (58.22 KiB) Viewed 92 times
SDO latest_512_HMII.jpg (16.82 KiB) Viewed 92 times
EGRAY_OBSERVATORY
Re: 4-4-2021 1st light this year - of my 3-lights FD's
a
Has thanked: 1247 times
Been thanked: 677 times
Post by ffellah »
Thank you Terry !
EGRAY_OBSERVATORY
Your welcome Franco
Has thanked: 2654 times
Been thanked: 2347 times
Post by DeepSolar64 »
Great work Terry! It’s nice to see you back in the game!
JochenM
Has thanked: 481 times
Been thanked: 803 times
Post by JochenM »
Glad to see you up and running again, Terry. Much more sessions to follow hopefully :)
Has thanked: 4057 times
Been thanked: 1780 times
Glad to see you back up and imaging Terry!
EGRAY_OBSERVATORY
Many thanks James, Jochen and Mark.
At least as James has said, I can do what the observatory was meant for albeit the likkle laptop is only any-good for imaging. I transfer to a better pc in-doors for processing.
Just shows how much better the large-monitors in the observatory (1=hi-rez, which can be swung-out close to the scopes for fine-tuning/focusing).
With my less than good eye-sight at present, would normally be a breeze, so hopefully the u/s computer will be back in operation soon.
Best Wishes for Clear Skies (which is occurring here at present)...
MAURITS
Has thanked: 149 times
Been thanked: 338 times
Post by MAURITS »
Beautiful images and presentation Terry.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
EGRAY_OBSERVATORY
Many thanks Maurits - I am trying, but today was a tad too-cold and 50% cloud and haze too, so decided to stay in the warm instead.
Regards
