Sun @ 120mm 4th April
Has thanked: 4060 times
Been thanked: 1781 times
I'm really pleased with my new pier; realised today I could be out setup and observing just an hour after sunrise, and with MeteoBlue predicting 1" seeing I decided to gamble. I started off with CaK at 100mm and this was working ok, so decided to go for 120mm @ f28 with the IMX174 camera. First off in CaK, then as I could see the seeing rolling off I switched to the more seeing friendly Ha.
Imagenew-plage-cak-120-bw by Mark Townley, on Flickr
Imagenew-plage-cak-120-colour by Mark Townley, on Flickr
ImageNew-plage-Ha-120-bw by Mark Townley, on Flickr
ImageNew-plage-Ha-120-colour by Mark Townley, on Flickr
Imageold-plage-cak-120-bw by Mark Townley, on Flickr
Imageold-plage-cak-120-colour by Mark Townley, on Flickr
ImageOld-plage-ha-120-bw by Mark Townley, on Flickr
ImageOld-plage-ha-120-colour by Mark Townley, on Flickr
ImageNew-AR-Cak-120-bw by Mark Townley, on Flickr
ImageNew-AR-Cak-120-colour by Mark Townley, on Flickr
ImageNew-AR-Ha-120-bw by Mark Townley, on Flickr
ImageNew-AR-Ha-120-colour by Mark Townley, on Flickr
Not much done with these apart from a sharpen in ImPPG and some colour in PS. The Ha was with the Quark, the CaK with a triple stack sortie of CaK PST filters (it's first outing) - they definitely aren't configured right here as the chromospheric fringe is gone, and all it gave me over DS CaK is increased exposure time. With clear skies all day I did settle on a TS CaK configuration that gave improved results, but by then I was running at 60mm ~f40 with the drop in seeing. I will get these processed, but after completely running after disk space my laptop has been whirring away stacking for several hours now.
Today was nice weather 15c and blue skies, and after imaging enjoyed just looking for several hours visually with the DS90 watching the subtle changes of our star all afternoon. All good fun! More images to come, but I have to process them!
rsfoto
Has thanked: 2533 times
Been thanked: 1903 times
Re: Sun @ 120mm 4th April
Post by rsfoto »
Hi Mark,
Well done.
arnedanielsen
Has thanked: 100 times
Been thanked: 223 times
Post by arnedanielsen »
Beautiful work Mark!
Arne
Thanks guys, here's the full disk taken at 60mm f16
ImageCaK-FD-bw by Mark Townley, on Flickr
ImageCaK-FD-colour by Mark Townley, on Flickr
Boso36
Has thanked: 55 times
Been thanked: 47 times
Post by Boso36 »
Good work, Mark !
Very impressive. You have a good setup and obviously very knowledgeable and skilful.
Can you clarify, please, how your CaK setup is ? I thought you would need a Daystar Quark CaK eyepiece filter ? Are there other setups for CaK. Sorry I am not very knowledgeable in CaK imaging.
Not sure where your pier is, but it looks like its working for you.
Clear skies.
Magnus
EGRAY_OBSERVATORY
Been thanked: 1676 times
Post by EGRAY_OBSERVATORY »
Very well done, Mark and yes of course, early morning seeing is usually better than later-on, but I at least like my ZZZZ's even though occasionally i will work through the night on something and then get out to the observatory for that early-time.
Thanks for describing and sharing.
Has thanked: 1264 times
Been thanked: 685 times
Post by ffellah »
A very nice set, Mark. The Ha images came out really well.
DavidP
Has thanked: 30 times
Been thanked: 26 times
Post by DavidP »
Nice images Mark.
The Calcium are especially sharp
Martin_S
Has thanked: 144 times
Been thanked: 483 times
Post by Martin_S »
Wow the hi res Cak is amazing Mark, what 120mm scope did you use?.
Martin
H - alpha setup
Lunt LS60THa Tilt-Tuned Solar Telescope, LS50FHa solar filter front-mounted Double stack etalon. 2 x Barlow
Remote etalon and focusing control's ASI290mm Camera
White Light setup
Skywatcher ED72 ,100 f/10 Achromat Homemade solar wedge, IR cut filter, #58 green filter.
AZEQ5 Pro mount.
Darkside setup
Skywatcher ED72AZGTi mount , GSO RC6. Celestron Evolution mount
Has thanked: 2696 times
Been thanked: 2363 times
Post by DeepSolar64 »
I am glad you got some sun-time today. Nice images too!
JochenM
Has thanked: 482 times
Been thanked: 803 times
Post by JochenM »
Nice shots, Mark.
Will be interesting to see what you manage to squueze out of that TS CaK with a bit of tinkering (that's the fun part).
Has thanked: 1682 times
Been thanked: 1524 times
Post by Carbon60 »
A beautiful set of images, Mark.
Thanks everyone!
Yes Jochen, it will be fun to experiment with the TS CaK, at the moment i'm not seeing a huge difference between DS Cak, just the whites are brighter and the surface seems slightly darker and slightly more textured. I seem to have lost the chromospheric fringe too. This comes at the expense of more gain needed to keep exposure short. I need to experiment with the tuning more and also play around with the order of the filters in the stack too.
Magnus, my CaK filter is one of my own construction, using Edmunds Optics filters for blockers and filters from CaK PSTs, for the closeup images this filter combo sits behind an f28 telecentric beam. All the scopes I use for CaK work are achro refractors either working at native f10 or stopped down to give me f10.
Martin, the scope is a Bresser 127/1200 refractor, stopped down to 120mm. For narrowband solar it is a bit of bargain. I may try it at full 127mm aperture for Ha next time the seeing is playing ball, but this will give the Quark a slightly faster f-ratio to work with so potentially a trade off.
In the mean time, here's the image of AR12813, same as above, but processed with the NAFE software (see the image processing section), it certainly gives more texture compared to the ImPPG view, still cant make my mind up about it...
ImageAR12813-Ha-120-NAFE by Mark Townley, on Flickr
And yesterdays Ha full disk with the DS50...
ImageHa-FD-DS-bw by Mark Townley, on Flickr
ImageHa-FD-DS-colour by Mark Townley, on Flickr
Stardust5858
Has thanked: 312 times
Been thanked: 379 times
Post by Stardust5858 »
Brilliant you got your pier sorted out, so much easier for you now. Great you managed to get some data too. Cak looking good. There was an interesting filaprome too. I too managed to get some cak and ha but not processed any yet, lol. Thanks for sharing Mark.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Nec6 Eq Mount.
Mark,
Your Ha view pretty much matched my visual view yesterday. Nice work.
James.
MAURITS
Has thanked: 151 times
Been thanked: 343 times
Post by MAURITS »
A lot of beautiful work Mark.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
krakatoa1883
Has thanked: 110 times
Been thanked: 364 times
Post by krakatoa1883 »
Fine images, great CaK detail.
Raf
Thanks folks for your kind comments!
