Full disc 04-04-2021
rsfoto
Has thanked: 2509 times
Been thanked: 1890 times
Post by rsfoto »
Sunshine in HSA and here the discs.
H-alpha shows a lot of prominences around the limb. Two plages, one in the northern hemisphere at ~ +20° and ~ + 33° with a visible spot in the white light image. Possibly f it is stable it will get the number AR 12813 ¿?.
In the Southern hemisphere there are plages at ~ +54° and ~ -30° as well as ~ -18° and both plages are shosing black pores :o The question here is which one was there first in order to get the number AR 12814 ¿?
As usual best seen in original size in a new tab/window :bow2
BTW the magma is still flowing from the 2 vents in Geldingadalir, Iceland. It is a very liquid basaltic magma coming from about 20 km depth.
https://www.volcanodiscovery.com/fagrad ... alley.html
JochenM
Has thanked: 481 times
Been thanked: 803 times
Re: Full disc 04-04-2021
Post by JochenM »
Nice (as always), Rainer.
Some exquisite detail in those finer/smaller proms.
Has thanked: 4057 times
Been thanked: 1780 times
Great disks as always Rainer, they look good!
Has thanked: 2654 times
Been thanked: 2347 times
Post by DeepSolar64 »
WoW Rainer. Those SE pores were so small that I think I simply overlooked them yesterday.
MAURITS
Has thanked: 149 times
Been thanked: 338 times
Post by MAURITS »
Nice to see Rainer.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
rsfoto
Post by rsfoto »
Yes, it got the number. ;)
NOAA_ AR12813.JPG (45.79 KiB) Viewed 24 times
I just checked SDO and the pores of the other two I saw yesterday are barely visible if non existant.
I just got two pores visually in the SE using a friend’s TV-85 refractor at 100x.
