April 4 2021 Observations
Has thanked: 2696 times
Been thanked: 2363 times
Post by DeepSolar64 »
Session time is 10:50am until 1:00pm EDT local time ( US ). The skies are clear and the temp is 64F. The seeing is surprisingly good at the beginning of the session but fades to only fair by session's end. Clay and I observed white light using his TeleVue 85 apochromatic refractor from his home in Rock Hill S.C.
Coronado SolarMax II 90 DS. 32x, 44.5x, 64x and 133x ( Ha )
There are three plages on the disc today. Two in the SE and one seen in the NW. I see three filaments in the SW and two in the far north. I can see several prominences around the limb but most are small wisps. One however is bright with some size to it. It's a north leaning triangle showing some detail within it. It is located on the SW limb.
The spicule layer is impressive at high power showing the individual blades easily on the limb.
The mottles are easy today showing excellent contrast and hinting at finer detail.
TeleVue 85 w/Lacerta wedge and 540nm filter 100x ( WL )
I can see two sunspots in the NW plage. The bigger one is to the SW of the smaller one. I can see some hint of the faculae surrounding them. The granulation is easy at session beginning but has became more difficult at session's end. I did not notice faculae to the other two SE plage systems.
Happy Resurrection Day!
PNG image 3.png (1.41 MiB) Viewed 82 times
And away from my ZWO camera an iPhone pic. The image should be flipped horizontally but you’ll get the idea. The large lit area next to the prom is just glare. The pic was just a quickie.
EGRAY_OBSERVATORY
Been thanked: 1675 times
Re: April 4 2021 Observations
Post by EGRAY_OBSERVATORY »
Many thanks James and much as i saw and imaged.
Have a good break away.
Thanks Terry! I am glad to see you back active again.
Has thanked: 1682 times
Been thanked: 1523 times
Post by Carbon60 »
Thanks, James.
Stu
JochenM
Has thanked: 482 times
Been thanked: 803 times
Post by JochenM »
Thanks for the report, James.
Has thanked: 4060 times
Been thanked: 1781 times
Thanks for the report James, I spent yesterday afternoon viewing the prom you imaged using my DS90. Sounds like you and Clay had fun! :)
Mark,
We had fun. Doing solar and observing last night as well. I did somehow miss those pores in the SE yesterday. I did not see them on the SDO image at the time and I may have been a bit distracted too. They were really small but the seeing was good enough to allow over 100x on the scopes. They should have been visible. I’ll look closer today and see if they are still there.
P.S. Looking back I see at least one pore on the SDO image. It looks like I just plain overlooked it. 😟
MAURITS
Has thanked: 151 times
Been thanked: 343 times
Post by MAURITS »
Thanks for the update James.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
